Sinusoids and Phasors (Micro-Cap)
2 replies · 3K views · last reply
EmBista
Circuit schematic of a series RLC network driven by a 5V 10KHz AC source, with a 2K resistor, 10nF capacitor, a 3K resistor and 80 mH inductor, labelled V1 through V4 and current I.
Hi,
I've been trying to figure this out for a while, its really annoying because it should be straight forward but its troubling me a lot.
The exercise is a practical on Sinusoids and Phasors. We are given the circuit and have to first calculate the voltage and current for each component and then 'measure' using Micro-Cap.
I calculated these to be:
V1: 2.360∠3.68°V ____ I1: 1.18∠3.68°mA
V2: 1.878∠-86.32°V __ I2: 1.18∠3.68°mA
V3: 3.030∠34.51°V ___ I3: 1.01∠34.51°mA
V4: 3.030∠34.51°V ___ I4: 0.61∠-55.18°mA
Can anyone confirm these?
Also, does anyone have any experience with micro-cap?
I am using version 10.0.8 and the results from the analysis on microcap don't make sense at all. So I have a few questions on how to set this up.
Thank you
  • Circuit schematic: 5V 10KHz AC source feeding a series chain of 2K resistor (V1), 10nF capacitor (V2) and current I, then a 3K resistor (V3) and an 80 mH inductor (V4) in parallel branches.
Your calculated values appear to be fine.
I've never used MicroCap, but I assume it's a Spice engine of some form; I use LTspice when I need a simulation. In what way do the results in MicroCap not make sense? Can you be more specific?
In MicroCap we were supposed to draw the circuit and measure the voltages and estimate the phase angle.
I did this correctly, however for the voltage across the capacitor I calculated it to be 1.878∠-86.32°V but when I look at the graph and I calculate the voltage drop (2.64-3.049=-0.409)
I must be doing this wrong?
Simulation screenshot: a circuit schematic with source V1, resistor R1 2000, capacitor C1 10n, resistor R2 3000 and inductor L1 80m, above a graph of sinusoidal voltages v(1), v(2) and v(3) in volts, with peaks labelled 4.999, 2.64 and 3.049.
  • Simulation plot of sinusoidal voltages v(1), v(2) and v(3) in volts over time, with a circuit schematic below showing V1, R1 2000, C1 10n, R2 3000 and L1 80m, with peak labels 4.999, 2.64 and 3.049.
