cianfa72
- 3,011
- 313
Which is the natural embedding of the cube in ##\mathbb R^3##, how is it defined?
What embedding did you have in mind in post #10? You're the one that introduced the idea of a cube in 3D Euclidean space.cianfa72 said:Which is the natural embedding of the cube in ##\mathbb R^3##, how is it defined?
I was thinking about the "visual" image of the 3d cube surface inside the 3-d Euclidean space. However to formally define an embedding we need a topology already defined on the cube and an homeomorphism onto its image in ##\mathbb R^3##.PeterDonis said:What embedding did you have in mind in post #10?
If that's all you have, you don't have a "cube". The word "cube" specifically implies more than that. It implies a specific geometric shape, with 6 identical faces, 12 identical edges, and 8 identical corners.cianfa72 said:to formally define an embedding we need a topology already defined on the cube and an homeomorphism onto its image in ##\mathbb R^3##.
You get the same situation with the absolute value function ##M=\{(x,|x|)\,|\,-1<x<1\} \subseteq \mathbb{R}^2.## The cube has only a lot more cases to define it.cianfa72 said:Which is the natural embedding of the cube in ##\mathbb R^3##, how is it defined?
The manifold has a priori no "smooth structure", i.e., there's no definition of derivatives there. The aim in the theory of differentiable manifolds is to define such an idea, and the construction principle is to map the set of points, making up a Hausdorff topological space, to the ##\mathbb{R}^d## and then via these maps you are able to define differentiation for functions defined on open subsets of the manifold in terms of differentiation of functions defined on open subsets of the ##\mathbb{R}^d## (with the standard topology). To make this consistent you need these constructions of charts and atlasses and all that.cianfa72 said:That was basically my point: we need a smooth structure for the manifold in the first place; only then you can check if a given function defined on the manifold (e.g. a coordinate function) is indeed a differentiable smooth function or is not.
Sorry, the homeomorphism between the 2-sphere and the natural embedding of the cube in ##\mathbb R^3## does not allow to define a smooth structure on the cube embedding's image ?fresh_42 said:The cube with its natural embedding doesn't allow a differentiable structure. If we transform it homeomorphic into a sphere, then we can use the new embedding for a differentiable structure.
The homeomorphism (##C^0##) between the cube and the sphere is not differentiable (##C^1##).cianfa72 said:Sorry, the homeomorphism between the 2-sphere and the natural embedding of the cube in ##\mathbb R^3## does not allow to define a smooth structure on the cube embedding's image ?
Yes, the function is continuous but it is not everywhere differentiable (the derivative is undefined at ##x = 0##).cianfa72 said:The set ##M=\{(x,|x|)\,|\,-1<x<1\} \subseteq \mathbb{R}^2## is the image of a continuous injective function ##f## from ##\mathbb R## to ##\mathbb R^2## (both with their Euclidean topology).
No, we can't, because of the lack of differentiability described above. "Smooth" implies differentiability everywhere on the domain.cianfa72 said:we can endow the set ##M## with a smooth structure
I'm not sure about this. We've just one chart (the homeomorphism with ##\mathbb R##) and so by definition the above set ##M## endowed with that chart is a smooth manifold. As said before that homeomorphism is not however a smooth immersion in ##\mathbb R^3##, so it is not a smooth embedding.PeterDonis said:No, we can't, because of the lack of differentiability described above. "Smooth" implies differentiability everywhere on the domain.
Yes, it is the graph of the continuous function ##x\mapsto |x|.## This graph is a one-dimensional manifold.cianfa72 said:The set ##M=\{(x,|x|)\,|\,-1<x<1\} \subseteq \mathbb{R}^2## is the image of a continuous injective function ##f## from ##\mathbb R## to ##\mathbb R^2## (both with their Euclidean topology). ##f## is also homeomorphism onto its image i.e. it is a topological embedding.
Do it. I'm curious how your tangent at ##(0,0)## will be defined. Homeomorphisms are not diffeomorphisms. If this was true, we could use the chain rule and construct a tangent of ##x\rightarrow |x|## at ##x=0.##cianfa72 said:Using such homeomorphism ##f##, we can endow the set ##M## with a smooth structure (only one chart) turning it in a smooth manifold.
This doesn't make any sense. How do you even define "smooth" without relating to ##\mathbb{R}^n##?cianfa72 said:However this smooth structure is not compatibile with the given smooth structure from ##\mathbb R^2##.
If the same applies, why do you want to complicate the issue?cianfa72 said:Coming back to the 3d cube surface I think the same applies to it:
You are repeatedly confusing several different concepts. You mix surfaces with functions, properties of functions with properties of spaces, you use embeddings without need, and I think (my impression) you do not know what a differential manifold is. Forget about the atlas, forget the embedding. Take a path on the manifold and define its tangent bundle.cianfa72 said:starting from a topological 2-sphere we can define the standard/canonical topological embedding of the cube within ##\mathbb R^3##. Even in this case we cannot define a smooth structure on the topological embedding's image in ##\mathbb R^3## compatibile with the standard smooth structure of ##\mathbb R^3##.
If that's all you have, you don't have a smooth structure. As has already been pointed out, a smooth structure requires differentiability. A homeomorphism by itself does not give you differentiability.cianfa72 said:We've just one chart (the homeomorphism with ##\mathbb R##)
That discussion is mixing up two different things. The "projection map" that is defined there does not give you a "one-dimensional manifold" that matches your definition of ##M##. The projection is ##(x, y) \to x##, which throws away information that is necessary for your definition of ##M##. All you are left with is the open set ##(-1, 1)## on the real line, with no other structure at all. You can of course define a "one-dimensional manifold" on this topological set, but this manifold will not meet your definition of ##M##.cianfa72 said:
This is a smoke grenade. What does admit mean? Obviously a homeomorphism here. But a homeomorphism isn't differentiable. The "as a topological space" meansYou can say that it is not a differentiable submanifold of ##\mathbb{R}^2## but, as a topological space, admits a smooth structure, i.e. is homeomorphic to a smooth manifold.
fresh_42 said:Only if you blow it up to a 2-sphere and "smoothen" the corners.
Surely I'm wrong, but to me this claim is clear.You can use a single chart, for that matter. So, yes, you have a smooth structure on M, but with that structure it is not an embedded (smooth) submanifold of ##\mathbb R^2##.
Yes, it's clear, and wrong. You are claiming that you can have a smooth structure on ##M##. But as you have defined ##M##, that's not possible. You can have a smooth structure on the open set ##(-1, 1)## of real numbers, but that set is not ##M## as you defined it.cianfa72 said:Surely I'm wrong, but to me this claim is clear.
You have made the same claim several times now, and each time you have received the same explanation of why it is wrong in response. How many times are we going to go around this merry-go-round?cianfa72 said:to me this claim is clear
Ok. This thread is now closed.cianfa72 said:No more time...I'm definitly wrong.
