So we have problems with clocks measureing time ?
  • Level: Graduate
  • Thread starter Thread starter Doctordick
    Clocks Time
215 replies · 27K views · last reply
Chronos said:
Footnote: The reason some of us are so 'dogmatic' about GR, is because it has passed, with flying colors, every test devised to prove it wrong. Nobody said it was perfect, just that is more so than any alternative explanation offered to date. Perhaps someday we will scoff Einstein in the same way we scoff at Newton. But, today is not the day.
Who is scoffing at Newton? Einstein's improvements to theory do not lessen Newton's role in any way. Theory is not reality. Theory is a useful model of some realm of reality. So hooray for Newton, and Einstein, and anyone who can improve on GR!
4Newton said:
First. In my example H is moving at a velocity faster than M and the tick rate should be faster.
If H is moving faster, its tick rate is slower.
Second. Are you saying that acceleration has something to do with the the clock rate?
Absolutely: acceleration is how you start moving.
Again, this is experimental fact: that's what happens to GPS satellites when you put them in orbit. And the the clock rate doesn't depend on the orbital inclination - as it should if what you propose is true.
What you have here is a convoluted "Twins Paradox." Are you familiar with that? The way you solve the paradox is through SR and accelerating one clock to meet the other in the other's frame.
Again, did you read the presentation I linked?
Indeed - in many ways Newton did more than Einstein. No math to describe your theory? No problem - invent a new branch of math!
I've made two very basic points in this discussion. One, that as a measure of specific motion, time effectively travels in both directions, with the frame of reference moving opposite the specific.
Two, that not only is space an absolute, but is the basis of the abstraction known as absolute.
I am quite sure that had any potential flaws in this logic occurred to anyone, they would have expressed it.
I realize that most people naturally tend to ignore things which do not fit their assumptions, but this is one of the least curious groups I've ever butted into.
No, I am not an expert in math and science, just a long time observer, but sometimes the perspective of a little distance can be useful. Beliefs should always be subject to scepticism, or the conversation becomes irrelevant.
I also pointed out that geometry never got around to incorporating the zero and from this arises the presumption that space is a function of topology, rather then the basis of it. Also, points, lines and planes cannot have a zero dimension, only less than Planck scale, because any multiple of zero is zero.
Some of this is mine. Some of it is others. Open source logic.
At risk of sounding repetitive, there are no 'absolutes'. There is no absolute space, time, mass, or energy. If you truly think about it, this is obvious and indisputable. GR is correct, both physically and metaphysically. The speed of light is the closest thing to a reliable reference standard known. Find one with more predictive power and you will make history.
even if you found an absolute, whatever we witness in OUR frame is RELATIVE to that absolute...
Chronos,
You are not addressing my specific point. If all curvature balances out and space is ultimately flat, would this suggest an ultimate state of equilibrium, with expansion and contraction as fluctuations from the mean? While it cannot be reached, absolute zero is a legitimate point of reference with regards to temperature. If you have eliminated all such motion, there is no time, so this state doesn't therefore have any ability to fluctuate and so cannot be said to curve, so what remains, other than empty space? As I've pointed out, geometry has never considered the implications of zero, otherwise it wouldn't attempt to say points, lines and planes have a zero dimension. So what would zero in geometry be? It isn't a point. Empty space is the only logical answer that I can see.
So I've given three reasons why space is the essence of absolute. All methods of determining space as relative involve the proposition that it is a function of measuring properties relative to it, yet these properties must exist in an equilibrium; Matter/anti-matter. Expansion and contraction. As I've pointed out with time, given that it is a measure of relative motion, then the frame of reference is necessarily in motion as well. So what is the state from which these properties all fluctuate?
I have reached these suppositions out of a desire to make sense of the reality I find myself in. If I am in fact wrong, I would certainly like to find it out, but given the extent to which people tend to take assumptions as fact and build religions around them, a blanket assertion does not qualify are a logical rebuttal.
brodix said:
Chronos,
What specific point are you talking about?
Absolute zero cannot be reached. You answered your own question.
Geometry is a coordinate system. Zero in geometry is the center of the coordinate system [x,y,z = 0], How hard is that to figure out?
So I've given three reasons why space is the essence of absolute. All methods of determining space as relative involve the proposition that it is a function of measuring properties relative to it, yet these properties must exist in an equilibrium; Matter/anti-matter. Expansion and contraction. As I've pointed out with time, given that it is a measure of relative motion, then the frame of reference is necessarily in motion as well. So what is the state from which these properties all fluctuate??
You have given three reasons that don't make sense. Your conclusions, therefore, are suspect.
Not religion and no one is making blanket assertions, so far as I can see. As scientists, we routinely exclude assertions that are not affirmed by observation
You misunderstand the nature of your conundrum: YOU are the one making the assumption that needs to be substantiated here, not us. Since the laws of the universe work fine without assuming an absolute reference frame, it is unreasonable to assume one exists.
Chronos,
Maybe you could define your understanding of "absolute"
The center of the coordinate system is a point and a point is one. AS in two points define a line, three, not on the same line, define a plane(and a circle).
Consider; Three dimensions define volume, but space doesn't have a particular coordinate system, so any number of random coordinate systems can be used to define the same space. As all points are potentially the center of the universe, order requires a particular point of reference, so any particular coordinate system is a unit, a frame of reference. So your point that x,y,z=0 is only relevant if said coordinate system doesn't exist. As you quoted, "Absolute zero cannot be reached." If there are any subjective points on that coordinate system, then x,y,z, is simply the initial point of reference and does exist and so cannot be an absolute.
So what is zero in geometry, other then the empty space?
As I've had similar conversations on various forums, with a wide range of comprehension, I do know that these ideas possesses some degree of sense. I suppose I'm asking for too much here.
russ,
Of course! A universe in which ninety-six percent is invisible to everything but the math. Thank your lucky stars you're not accountants, or the IRS would be all over you.
The only alternative to Big Bang Theory that I recall was tired light. This doesn't even make sense to begin with. If light is encountering friction, proceeding waves/photons would encounter more then succeeding ones, so the wave length would be shortened. What about energized light; That decreasing amplitude is transferred to expanded frequency, like cracking a whip?
As gravity causes space to collapse and as gravitational processes are shedding temendous amounts of radiation, wouldn't this radiation cause space to expand? As in;
http://www.economist.com/science/displayStory.cfm?story_id=2404626
If space does expand, but the universe, already being infinite, doesn't, wouldn't this result in more pressure on existing gravitational systems, thus causing the effect currently assigned dark matter?
As light from distant sources is clearly magnified by the lensing effect of intervening galaxies, wouldn't this result in a blueshift effect that would reduce the overall redshift and that given the distribution of galaxies, the light of distant sources is going to pass through proportionally more residual gravity fields than closer sources, it would seem that the result would be that the closer sources have a greater average redshift, thus creating the immpression that the rate of expansion is increasing... I think I've probably hit a few mental roadblocks, so I'd leave it at that...
regards,
brodix
Are you talking about dark matter? That has nothing at all to do with this thread.
This also has nothing to do with this thread...nor does the rest of your post.
The nonexistence of a universal reference frame is the inevitable conclusion of a boatload of experiments - not the least of which was the Michelson-Morley experiment.
Russ,
Yes. There is no universal reference frame. Order is a function of perspective, which is relative. Every point is effectively the center of the universe, the x,y,z. So space is effectively infinitely dimensional. When we try to order it, we assign it a specific reference frame. But the map isn't the territory.
As I've pointed out; In that there are effectively two directions of time within the context of what exists, ie. is present, the past is what is ordered and the future is the random energy that is necessary for order to continue. The order/definition that is the past motivates the energy that ensures the future, while the energy of the future motivates the order of the past. (This is essentially complexity theory, with the present as the complex phase transition between order and chaos. Top down order of the set. Bottom up growth of the process.)
Back to space; The reference frame is order. As such it is a closed system and subject to entropy, ie. in and of itself, it loses energy. Therefore it must have an input of raw energy to continue. This energy is necessarily chaotic. (As I'm sure this description probably seems to you.)
So, yes, there is no universal frame of reference, but the absolute isn't a frame of reference, it is the neutral state, around which matter collapses and energy expands.
Space.
See if you can dig down just a little on this. The see no evil, hear no evil, speak no evil routine gets boring.
Most of you have completely missed the point!
Well, I am back. I quickly read through the thread. It seems to contain a lot of posts having little to do with my original statement. I find a lot of posts concerned with the definition of time, but no post that made any serious attempt to define what the poster meant by the term. A couple gave a rather superficial definition: those generally contained the term "rate" which clearly requires a definition of time and thus cannot be used in a serious definition of time.
I found (and of course this decision is made with limited knowledge) only two posters with seemingly rational positions and am very sorry to find them arguing with one another. That would be 4Newton and russ_waters. Russ seems to have a better education but 4Newton seems to be more ready to think for himself. Russ, I think you should be more tolerant of his mistaken perceptions and seriously consider your responses to him.
Russ, I am afraid you have been a little sloppy in your criticisms (or corrections) of 4Newton's comments. Yes, his interpretations are a bit askew of the standard but he is not as far from understanding as the others on this thread. Plus that, he has an open mind to issues you deem settled and beyond question.
First I would like to comment on your rather cavil explanation of the relationship between special and general relativity.
russ_watters said:
Einstein proposed SR because of a known difficulty in reconciling the observation that C is constant with Newtonian physics. GR came about because of inaccuracies in Newtonian predictions about the orbits of planets.
The theory of relativity existed before Einstein; however, it was not called a theory because everyone thought it was correct. As far as I know, it was first proposed by Galileo but the consequences were thoroughly implemented by Newton. The issue is the fact that all of physics must be independent of your personal frame of reference. From Newton's perspective, Euclidian geometry was the only rational geometry to use. As a direct consequence, the conversion from one frame of reference to another (presuming the x-axis is parallel to the velocity vector) was accomplished via t'=t, x'=x+vt, y'=y and z'=z: where the origins of the two were in the same place when t=0.
It is, in fact, the presumption of most that Newton's assumption was absolutely correct which leads to the problems most have with modern analysis of relativity. But let us leave that issue for the moment. What is important here is that Newton's relativity is entirely general and much useful physics flows from that fact. Newton defined an "inertial frame" as the frame where [itex]\vec{F}=m\vec{a}[/itex] is a valid expression. Of great importance is the fact that accelerated reference frames (frames which are not "inertial") are as useful as inertial frame so long as the consequences of that acceleration are taken into account.
In particular, rotation leads to effects which are very significant. Centrifugal and coriolis forces are direct consequences of using rotating coordinate systems. The major problem with "special" relativity is the fact that it only provides the relationship between reference frames in the total absence of acceleration. That is, it fact, why it is called "special" relativity!
A complete theory must be entirely "general". That is why a "theory of general relativity" was required! Without a "general" theory, we are in as much trouble as we were without the "special" theory. The fact that gravitation could be explained as a consequence of "general" relativity was more of an overwhelming support of Einstein's theory than a necessity of it.
With regard to this issue, you are being a little provincial to say the least. It would be better if you were to say," Since most of[/color] the laws of the universe work fine without assuming an absolute reference frame, it is unreasonable to assume one is required to explain most phenomena[/color]. With regard to your "generalization", I would like to bring to your attention the following:
In 1989 the (COsmic Background Explorer) mission was launched. One of its missions was to measure the temperature of the universe accurately. COBE found that the temperature of the universe is 2.725 K. This temperature agrees remarkably well with that predicted by the Big Bang theory.
But COBE scientists didn't stop there. They noticed that the universe looked a little cooler in one direction, and a little warmer in the other direction. This is called the dipole variation and is caused by the Doppler effect of our solar system's motion relative to the cosmic background radiation, enabling the COBE scientists to measure the speed of the solar system: 371 km/sec[/color].
Check out http://lambda.gsfc.nasa.gov/product/cobe/
Thus it seems that a valid explanation of the Universe does indeed include a natural unique coordinate system. What I would say is that "special relativity" (the idea that ignorance of distant events is not detrimental to our study of physics) is a very valuable tool for setting up constraints on what is to be expected but is certainly not a "proof" that all physics must be frame independent. In fact we have direct evidence (given above) that all physics is not frame independent.
Have fun -- Dick
How do you define 'rate'? All definitions I am aware of include the variable 'time'. Please explain how a 'serious discussion of time' excludes time.
He did.
Because 4Newton was wrong. The issue is settled until new evidence is introduced to refute it. The 'best proven' explanation must be preferred over the 'best unproven' explanation.
That makes no sense. There is no 'modern analysis of relativity' that disagrees with conventional relativity.
Agreed, SR does not include gravity.
There is no evidence a 'natural unique coordinate system' exists. There is, however, enormous evidence it does not exist.
The CMB does indeed allow us to measure a speed with respect to it - however, that speed is not needed to make any of the calculations 4Newton was proposing. Therefore, its not a universal reference frame.
Sir Chronos, your responses show little if any thought.
We cannot have a serious discussion of anything without first defining what it is we are talking about. The issue of this thread is a concise and well thought out definition of "time". One of the first issues of definition itself is that the word being defined is not to be used in the definition. A definition which includes the word "rate" requires a definition of "rate" before it is useable. Since "rate" is generally defined as the ratio between change in something and the change in time, the concept presumes time is defined and thus is not a valid concept within the definition of time.
Chronos said:
He did.
I would say he is still missing some subtle issues!
It appears to me that you have a lot of confidence in what has and what has not been proven. I think it would benefit you to take a little trouble to think about these things.
Now I would contend that is a rather extreme statement. They certainly disagree as to the proper equations to be used to transform from one coordinate system to another. You should be more careful in your pronouncements.
Neither did Newtonian relativity! What is much more significant is that SR does not include a rule for transforming between accelerating coordinate systems which Newtonian relativity does. It was Einstein's attempts to generalize his theory (an absolute necessity by the way) which lead to the gravitational results. If you look at the fundamental deduction of general relativity, you will find discussion of direct transformations from a coordinate system attached to an accelerating elevator. Problems in measurement arose there which did not allow a simple generalization thus einstein's result was not unique. A very interesting problem which has received little really serious attention.
Now here you are fighting a losing battle as "natural unique coordinate systems" are use all the time on a day to day basis in physics. In fact, lots of different "natural unique coordinate systems" are used. For example, the rest frame of the laboratory in which an experiment is done; or a coordinate system which makes the one way speed of light the same in all directions.
The central issue of relativity is that all these coordinate systems are equally valid. In almost every case, each and every experiment suggests it's own "natural unique coordinate system". It is the fact that the "laws of physics" must be the same in all of these coordinate systems which allows us to determine the required transformation equations between those various coordinate systems.
And finally, to Russ, I still say you are being a bit provincial with your comments. I think it would be worth your while to step back once and look at the fundamental nature of the problems which confront us.
I would expect a mentor to take a little more care with his comments. What you say cannot possibly be rationally defended as logical.
You are saying that because "that speed is not needed to make any of the calculations 4Newton was proposing", it is not a universal reference frame.
You seem not to understand the principle of relativity. The principal or relativity is that all reference frames capable of indicating the information associated with any given experiment are fully useable. If one adds to that the fact that the laws of physics are particularly simple in a specific frame (think of Newton's inertial frame), then all one needs is the specific transformation from the particular simple frame to a frame of reference of interest and one knows what happens in that frame of interest. Einstein's General Relativistic frame is just such a "simple" frame, quite analogous to Newton's inertial frame; however, the required transformations to the frames of interest are not quite as simple as Newton's but they can nonetheless be done.
That fact is used over and over again throughout physics. There are a number of unique frames used all the time. For example, the GPS system is a coordinate system tied to time as measured by a clock in Colorado and is by that fact, a very unique coordinate system. Since it is always possible to set up a specific coordinate system tied to a specific clock the term "universal" could be attached to the concept.
There is another rather unique coordinate system used quite often in a lot of experiments. That would be a coordinate system tied to center of mass of the universe (in this case, read "universe" to be a reference to the collection of entities which are significant to the experiment of interest and may range from no more than the components of a single nucleus to a nuclear accelerator, the solar system, the galaxy or everything including the cosmic background). Call such a coordinate system a CoM system. Certainly the CoM system is unique and it is also quite universal. One can very reasonably suggest that relativity should require the laws of physics to be the same in every CoM system conceivable.
In fact, that is essentially exactly what the COBE scientists did when they documented the solar systems velocity through the universe at 371 km/sec.
But all this is outside the discussion on this thread which is "what is the definition of time?"
Have fun -- Dick
Yes, it's not stable. It is expanding.
I understand that perfectly fine.
The problem is you misunderstand the word "universal" in this context. The preferred reference frame of GPS is clock in Colorado, but that doesn't make it The universal reference frame. They could use a reference clock located on the moon if they wanted too and the system would still work. The universal reference frame is the frame in which all experiments must be done to get correct results. In 4Newton's experiment, for example, only velocities measured against this frame would give "correct" time dilation readings. The M&M experiment works the same way. The logic is sound, but the evidence says this frame doesn't exist: and Relativity (and yes, I did mention that the concept is common to Einstein and Newton) postulates it based on the evidence.
your reputation as a cranking troll is well deserved, Dr.Dick
how do you propose to define time without "rates" as you say. do you even have a method to do so? you propose the question "what is time?" then when people respond explaining that it exists as a function of "rates" you tell them they are wrong with no explanation. are you proposing a backwards step from the unification of space-time to space and time as separate constraints?
please enlighten us with your wisdom, or return to "whatever hole you came from" :D
All motion is relative. If you were to encompass all motion in the universe, it would be the universal reference frame, but you are not, you are measuring some specific process against the rest of the universe, which makes the entire universe relative to it. So, since you have isolated this particular motion from the universal flux, a negative remains. So the universe is effectively moving toward the specific motion, as it moves toward it. Or to put it simply, "For every action, there is an equal and opposite reaction."
No mention of time or rates.
brodix said:
Dr. Dick,
What is the definition of time?
I know what I am talking about when I use the term! The question is, do you? If you do, you should make your position clear; if you cannot, then you clearly do not know what you are talking about.
Think it out!
Have fun -- Dick
Can you give any evidence of that fact? That is, how do you alone happen to be aware of the fact that the value is changing. Please give me your experimental reference to the fact that the value 371 km/sec is changing.
Have fun -- Dick
are you familiar with the term "Hypocrisy" then, Dr.Dick?
Ok, though I can assure you that you will not be able to comprehend it, I will nevertheless give you exactly what I mean when I use the term: time is an ordering of what I know (and what I know changes). The past is what I know and the future is what I do not know (and have hopes of predicting). Time is nothing more than a parameter which I use to refer to a state of presonal knowledge.
Now that could make sense to you if you would take the trouble to think it out.
Have fun -- Dick
I would not argue with that in any way! In fact, that is exactly the issue underlying all of physics. How do I know that I understand the specific meaning of any word you use? You need to define these things and that is a major problem not considered by most.
If you want to discuss the central problem with defininition itself, I am very open to the issue. Are you?
Have fun -- Dick
I know what I mean when I use the term! Would you take the trouble to specify what you mean when you use the term?
Have fun -- Dick
now explain to me the difference of "what you know" versus "what you observe via tools or equipment"
your definition of time is not very useful for quantifying it, and relaying said information in a meaningful matter to another individual...
And nothing defined either!
Have fun -- Dick
