Soft gluons and colinear gluons
  • Thread starter Thread starter varphi42
    Gluons
Soft gluons are characterized by low momentum and energy, while collinear gluons are emitted in directions close to the beam axis, resulting in low transverse momentum (PT). Although soft and collinear gluons can overlap, they are defined by different criteria: soft gluons have small energy, and collinear gluons are aligned with the beam direction. The probability of gluon emission from a quark demonstrates that gluons are predominantly emitted in both soft and collinear states. Understanding the distinction and relationship between these types of gluons is crucial in high-energy physics.
varphi42
Is there a difference between soft and colinear gluons?
Are soft gluons the ones with small energy, or with small PT with respect to the qqbar axe (in this case soft and colinear would have the same meaning)?
Usually soft gluons are those with low momentum, i.e. the less energetic ones, while collinear gluons are those produced near the beam direction, i.e. with low PT.
Obviously a gluon can be both soft and collinear. In fact, one can show that gluons are mostly emitted soft AND collinear as the probability of emitting a gluon from a quark is given by:
$$dP_{q\rightarrow qg}\propto \frac{dk}{k}\frac{dk_\perp^2}{k_\perp^2}$$
and so the probability is strongly centered around k≈0 (soft) and PT≈0 (collinear).
Ok thank you!
