Imaginary Solutions to Radical Equations
  • Thread starter Thread starter Repetit
The equation Sqrt(x) + 1 = 0 has no solution in the realm of real numbers, as the square root function is defined to yield only positive real numbers. Conversely, the equation x^2 + 1 = 0 lacks solutions in real numbers unless the imaginary unit i is introduced. Defining a unit for Sqrt(x) + 1 = 0 is deemed unnecessary due to its impracticality. In complex numbers, however, the square root function allows for multi-valued solutions, where -1 can be a square root of 1, leading to x = 1 as the only solution for Sqrt(x) = -1.
  • Understanding of complex numbers and the imaginary unit i
  • Familiarity with the properties of square root functions
  • Knowledge of multi-valued functions in mathematics
  • Basic algebraic manipulation skills
  • Study the properties of complex numbers and their applications
  • Learn about multi-valued functions and their implications in mathematics
  • Explore the definitions and properties of square root functions in both real and complex domains
  • Investigate the historical context and practical applications of imaginary numbers
Mathematicians, students studying advanced algebra, educators teaching complex numbers, and anyone interested in the theoretical aspects of radical equations.
Repetit
Does the equation Sqrt(x) + 1 = 0 have a solution? I would say that it doesnt. But the equation x^2 + 1 = 0 doesn't have a solution either, unless you define the imaginary unit i as the solution to the equation.
So why don't one define some unit which is the solution to the equation Sqrt(x) + 1 = 0? Is it simply because it is of no practical use?
Mathematics news on Phys.org
\sqrt{i^{4}} +1 = 0
Of course, i4= 1!
Repetit, if you are referring to the square root function as defined for real numbers, then \sqrt{x} is specifically DEFINED as "the positive real number whose square is x". By that definition, it is impossible that \sqrt{x}= -1.
If, however, you are referring to the square root function as defined for complex numbers, where 'multi-valued' functions are allowed, then -1 is one of the two square roots of 1. The only solution to the equation \sqrt{x}= -1 is x= 1.
Hmm, I see, that makes sense. Thanks to both of you!
  • · Replies 45 ·
  • · Replies 16 ·
