Solve 10 Gal Solution of 6.40%Cl, 5.52%Na, 4.11%Ca, Density 1.21
  • Thread starter Thread starter nikkee
    Chem
The discussion revolves around solving a problem related to a 10-gallon solution containing specific percentages of chloride (Cl), sodium (Na), and calcium (Ca), with a given density. Participants are exploring how to adjust the concentration of Cl by adding hydrochloric acid (HCl) and are interested in the theoretical effects on the concentrations of Na and Ca after this addition.
  • Homework-related
  • One participant requests a step-by-step explanation for calculating the amount of HCl needed to increase the %Cl from 6.40% to 6.60% and the resulting %Na and %Ca.
  • Another participant suggests that density is relevant for starting the solution but notes that the concentration of the HCl source is not provided.
  • A third participant provides the concentration of HCl as approximately 32% by weight.
  • One participant emphasizes the importance of units, particularly the units of density, and assumes that the percentages are by weight, recommending the calculation of the total mass of the solution.
  • Another participant advises checking unit conversion ratios to convert gallons to pounds and suggests converting the density into pounds per gallon to facilitate calculations.
  • This participant also mentions using a variable to represent the mass of HCl solution to be added in the ratio for calculating the new %Cl.
Participants generally agree on the need for careful unit conversions and the importance of understanding the relationship between mass and concentration. However, there is no consensus on the exact steps to solve the problem, and multiple approaches are suggested.
Limitations include the lack of specific information about the concentration of HCl in terms of volume, as well as the need for precise unit conversions that are not fully resolved in the discussion.
nikkee
Could someone explain to me how to solve this?
I have a 10 gallon solution made up of 6.40%Cl, 5.52%Na, and 4.11%Ca, with a density of 1.21. How much HCl is needed to get the %Cl up to a 6.60%, and what would the theoretical %Na and %Ca be after the HCl addition?
Can anyone show me the steps to solve this?
How about just a couple of hints!
The density information is only to help start the solution of the problem. You are adding a number then to both the mass of the liquid and to the mass of Cl, from the addition of HCl. (we notice that your concentration of HCl source is not given).
The concentration of the HCl is ~32% by weight.
You absolutely need to pay attention to units. What are the units of density you have given?
I'm assuming your percentages are by weight. Figure out how much mass you have in ten gallons of solution; use molecular weights to do this.
That would be a good starting point.
You will need to check a handbook unit conversion ratios to go from gallons to pounds, which is why you will need also to convert the density into pounds/gallon. The best of memory suggests that 453.59 grams = 1 pound; 2850 milliliters = 1 gallon. Convert your 10 gallons of mixture to its number of pounds.
Now, you need to choose a variable to apply to both the numerator and denominator of a ratio representing the "percent" of Cl. The variable will be the amount of mass of HCl solution which you want to add to your 10 gallons of mixture. I will leave all of the algebraic transcription to you.
  • · Replies 19 ·
10K
  • Sticky
  • · Replies 0 ·
18K
