Solve the Puzzle: 4, 5, 14, 185, .... - Ray Salmon
  • Context: MHB
  • Thread starter Thread starter karush
The discussion focuses on solving the numerical sequence 4, 5, 14, 185, and determining the next number in the series. Participants analyze the differences between the numbers, identifying patterns and polynomial functions to generate the series. Notably, one participant concludes that the next number is 34,214, derived from the relationship where each number is 11 less than a perfect square. The conversation also touches on the limitations of series generation and the arbitrary nature of some solutions.
  • Understanding of polynomial functions and their applications
  • Familiarity with numerical sequences and series generation
  • Basic knowledge of mathematical patterns and differences
  • Experience with online mathematical tools like Wolfram Alpha (W|F)
  • Explore polynomial fitting techniques for numerical sequences
  • Learn how to use Wolfram Alpha for series generation and analysis
  • Investigate mathematical patterns involving perfect squares and their relationships
  • Research alternative online calculators for sequence generation
Mathematicians, educators, students, and anyone interested in numerical sequences and mathematical problem-solving techniques.
karush
MHB
ok somebody sent me this on youtube but I don't think is a workable series
Rimbus Jift
@ray salmon Quick IQ test... Solve: 4, 5, 14, 185, ...
so first the difference between the numbers is 1,9,171so far just some ideas
The factors of 171 are 1, 3, 9, 19, 57, 171
$9^0 =1$ and $4+1=5$
$9^1 =9$ and $5+9=14$
$9+5=14$
$9+14=19$
$9\cdot 19=171 $
anyway ?
i plugged into W|F but didn't return a series
Mathematics news on Phys.org
Rimbus Jift
$9+5=14$
$9+14=19$
$9\cdot 19=171 $
anyway ?
You should know by now that you can choose any number to be the next one. For example we can use
[math]f(x) = -28 x^4 + \dfrac{917}{3} x^3 - 1130 x^2 + \dfrac{5014}{3} x - 815[/math]
and get f(1) = 4, f(2) = 5, f(3) = 14, f(4) = 185. and the next number in the series will be f(5) = 0.
-Dan
ok actually I haven't seen that,
the few series I worked on just plug and played with values of n till you got an eq to generate the series
the imperative "solve" does not insist that it is series generated by an eq but I assume that was the intention
why woufd f(5)=0 or is that just arbitrary
Anyway it does seem slam dung stuff
f(5) is arbitrary. For example:
[math]f(x) = -\dfrac{671}{24} x^4 + \dfrac{1221}{4} x^3 - \dfrac{27085}{24} x^2 + \dfrac{6677}{4} x -814[/math]
gives f(1) = 4, f(2) = 5, f(3) = 14, f(4) = 185, and f(5) = 1.
etc. And you can do other fits aside from polynomials pretty much so long as you have 5 unknowns and the system can be solved. (Polynomials are easy to fit which I why I prefer to use them for demonstrations.)
A problem like this assumes that you can figure out a pattern but unfortunately any more information that you might get could change that answer. So I feel that problems like this are just silly.
-Dan
ok I think so too ,...
but curious
what online series calculators are good if you just give a list of 6 numbers which assumes a generator eq
I guess W|F will but haven't tried
Someone just posted this on YT again in a random Covid video (9/10/23). I started down the same line as above, noticing the differences of each number in the series is a multiple of 3, but this didn't lead anywhere. I played with the numbers and realized they are each 11 away from a square.
In fact 4²-11 = 5; 5²-11 = 14; 14²-11=185. So the answer is 185²-11 = 34,214.
