Solve 5sinx +12cosx=6.5: 0-180 Degrees
  • Thread starter Thread starter fan_boy17
    Trig
To solve the equation 5sin(x) + 12cos(x) = 6.5 within the interval of 0 to 180 degrees, it's suggested to express the left side as a single trigonometric ratio. By dividing the equation by 13, the equation simplifies to (5/13)sin(x) + (12/13)cos(x) = 1/2. This leads to using the sine addition formula after determining the values of sin and cos for arccos(5/13). The approach emphasizes avoiding squaring both sides to prevent extraneous solutions. The discussion highlights the importance of proper trigonometric manipulation for accurate results.
fan_boy17
solve 5sinx +12cosx =6.5 between 0 and 180 degrees
i tried squaring both sides. (5sinx +12cosx)^2= (6.5)^2
25sinx +60sinxcosx +60sinxcosx + 144cosx^2 =42.25
Squaring isn't really a good idea since it might yield extraneous roots. Try writing the given expression as a single trigonometric ratio.
Hint : try converting it into a form of sin(x+T)
Sine is always postive between 0 and 180 degrees so you can write that as 5\sqrt{1- cos^2(x)}+ 12cos(x)= 6.5.
Rewrite it as 5\sqrt{1- cos^2(x)}= 6.5- 12 cos(x) and square both sides.
Or, you can divide equation by \sqrt{5^2+12^2} = 13, and you will have
\frac{5}{13}\sin x + \frac{12}{13}\cos x = \frac{6.5}{13} = \frac{1}{2}
And you know that \cos \arccos \frac{5}{13} = \frac{5}{13} and \sin \arccos \frac{5}{13} = \sqrt{1-\left(\frac{5}{13}\right)^2} = \frac{12}{13}
And then, use formula for \sin(x+y)
sorry for bad English
Excellent Engliosh, excellent mathematics!
This is exactly what I was suggesting. :smile:
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
