Solve a system of nonhomogeneous DEs
The discussion centers on solving a system of nonhomogeneous differential equations represented by the equation $$\ddot {\vec a}=A\vec a+B\dot{ \vec a}+\vec F$$ where A and B are known matrices and F is a constant vector. Participants suggest transforming the second-order system into a first-order system by defining $$\vec b=\dot{\vec a}$$, leading to $$\dot{\vec b}=A\vec a+B\vec b+\vec F$$. The conversation emphasizes the importance of handling the non-homogeneous term and suggests using characteristic equations and eigenvalue methods for solutions, particularly when A is invertible.
  • Understanding of second-order differential equations
  • Familiarity with matrix algebra and properties of matrices
  • Knowledge of eigenvalues and eigenvectors
  • Experience with characteristic equations in differential equations
  • Study the method of solving second-order linear differential equations with constant coefficients
  • Learn about the implications of matrix invertibility in differential equations
  • Explore the use of eigenvalues and eigenvectors in solving systems of differential equations
  • Review the application of the Laplace transform in solving nonhomogeneous differential equations
Students and professionals in mathematics, engineering, and physics who are dealing with systems of differential equations, particularly those requiring solutions to nonhomogeneous systems.
skrat
Solve
if A and B are known matrices and F is a constant vector.
My plan was to define ##\vec b=\dot{\vec a}## to move from second order to first order system ##\dot{\vec b}=A\vec a+B\vec b+\vec F##
But now... well, I have got absolutely no idea how to continue! I wanted to use theorem 23 on page 580 in chapter 11.7 in this work: http://www.math.utah.edu/~gustafso/2250systems-de.pdf BUT I have got a ##A\vec a ## term... which... wel... I don't know what to do with it!
skrat said:
Solve
If ##A## is invertible there is no reason to appeal to Theorem 23; that is just "overkill". Think first how you would deal with the scalar DE ##x'' = A x + B x' + c## when ##A, B, c## are constants and ##A \neq 0##.
In case of a scalar DE i would rewrite your equation to $${x}''-B{x}'-Ax=c$$
Than the solution of a complementary part are roots of this characteristic equation $$D^2-BD-A=0$$ meaning $$D_{1,2}=\frac B 2 \pm \frac 1 2 \sqrt{B^2+4A}$$ therefore $$x_{hom}(t)=C_1e^{(\frac B 2 + \frac 1 2 \sqrt{B^2+4A})t}+C_2e^{(\frac B 2 - \frac 1 2 \sqrt{B^2+4A})t}.$$
To get the particular solution we could guess it. Or not? Let's say $$x_{part}=C_0$$
Right?
Right?
If ##A,B,C## are constants and ##A \neq 0## the DE ##x'' = Ax + Bx' + C## is the same as the homogeneous DE
(x+C/A)'' = A(x+C/A) + B(x+C/A)' .
In your case it is not completely clear what to do in the case that ##A## is not invertible and the linear system ##Ar = F## has no solution.
BTW: my answer assumes that you know how to deal with the homogeneous system, and are just confused what to do about the non-homogeneous system (but with a constant "forcing" term).
If I understand you correctly, than in my case of system of equations and assuming A is invertible $${(x-A^{-1}C)}''=A(x-A^{-1}C)+B{(x-A^{-1}C)}'$$ with ##x## being a vector ##\vec x=(x(t),y(t))## or did I not understand you correctly?
Your assumption is wrong, to be honest. I am sure I used to know how to do this with matrices, yet I can't seem to remember, nor can I find any good paper with a nice explanation and an example.
However, if I define ##\vec y=(\vec x-A^{-1}C)## than the equation above can be written $${\vec y}''-B{\vec y}'-A\vec y=0.$$
Now all I was able to figure out from several papers is that it makes sense to define ##\vec u ={\vec y}'## to reduce the order of the differential equation. Doing so brings me to $$ { \vec u}'-B\vec u-A\vec y=0.$$
Now you can safely assume that the ##-A\vec y## term is confusing me. Without it I would find the eigenvalues and eigenvectors of a matrix B. With that term I have no idea!
You can check this for yourself: do you get back the same DE?
The pdf file you cited has lots of examples in it.
************************However, if I define ##\vec y=(\vec x-A^{-1}C)## than the equation above can be written $${\vec y}''-B{\vec y}'-A\vec y=0.$$
The standard method is to re-write your system as
\vec{y}' = \vec{u}, \; \; \vec{u}' = A \vec{y} + B \vec{u}
or
\frac{d}{dt}\pmatrix{y \\ u} = \pmatrix{0 & I \\ A & B} \pmatrix{y\\u}
This is of the form ##\vec{z}' = {\mathbf M} \vec{z} ##.
  • · Replies 35 ·
  • · Replies 19 ·
