Solve AC Voltage Form: RLC Series Circuit Power
  • Thread starter Thread starter Acuben
    Ac Form Voltage
3 replies · 7K views · last reply
Acuben
You don't even have to read the whole thing... just the red part is sufficient.
I saw this on the homework: V= (100 v) sin (1 000t)
What does this mean?
Can I treat it as having 100 real magnitude and 0 imaginary magnitude (and therefore 0 phase angle)? or does sin(1 000t) tells something about the phase angle?
or does sin (1 000t) tells something about angular velocity or frequency?
I can't solve this problem without knowing frequency or angular velocity
just for side note: let...
V= delta voltage
v= unit volts
uF= micro farad
H= Henries
RLC= i believe it stands for Resistance, Inductor, Capacitor
An AC voltage of the form V= (100 v) sin (1 000t) is applied to a series RLC circuit. Assume the resistance is 400 Ohms, the capacitance is 5.00 uF, and the inductance is 0.500 H. Find the average power delivered to the circuit
w= angular velocity (supposed to be omega)
L= inductor
C= capacitor
j= complex coefficient = sqrt(-1)
Zl= resistance of inductor
Zc= resistance of capacitor
Ztot= total resistance
R= resistance of resistor
P= Power
Xl=wL
Xc=1/wc
Zl=j*Xl
Zc=-j*Xc
Ztot= R + Zl + Zc = R + j(Xl-Xc)
P=I*V*(P.F)
P.F= Power Factor. Is is cos [tex]\varphi[/tex]
the angle between voltage and current.
by default everything is in RMS (rootmeansquare), but it shouldn't matter in calculation)
well it's easy except I don't know frequency nor angular velocity.
Otherwise finding Ztot will be easy and finding power is easy as well
Your voltage is V= (100 v) sin (1 000t), which is in the form V=V0sin(ωt).
hence the amplitude is V0 and the angular frequency is ω. Compare the terms and get ω.
The voltage at any instant T is V sin (wT) where w is (should be) omega, the angular velocity.
So, V is the peak voltage.
Omega = 2 * PI * F
In this case, omega = 1000 = 2 * PI * F ... so F = 159.154 Hz. ( ie 1000 / (2 * pi) )
V is the maximum voltage, but the actual voltage depends on the sine function, so the actual voltage can be anywhere between plus 100 volts and minus 100 volts, including zero.
For example what would the voltage be after 0.2 seconds?
V = 100 * sin (2 * pi * 159.154 * 0.2 ) or -34.2 volts
Thank you very much. I understood it now =D
