Solve Eigen Values/Vectors of Matrix w/ Repeated Eigenvalues
  • Thread starter Thread starter Number2Pencil
10 replies · 3K views
Number2Pencil
Find the eigen values/eigen vectors of
[tex] \left[<br /> \begin{array}{cc}<br /> 3&-1&1&1&0&0\\<br /> 1&1&-1&-1&0&0\\<br /> 0&0&2&0&1&1\\<br /> 0&0&0&2&-1&-1\\<br /> 0&0&0&0&1&1\\<br /> 0&0&0&0&1&1\\<br /> \end{array}<br /> \right][/tex]
The lambda equation is:
[tex] A - \lambda I =<br /> \left[<br /> \begin{array}{cc}<br /> 3 - \lambda&-1&1&1&0&0\\<br /> 1&1 - \lambda&-1&-1&0&0\\<br /> 0&0&2 - \lambda&0&1&1\\<br /> 0&0&0&2 - \lambda&-1&-1\\<br /> 0&0&0&0&1 - \lambda&1\\<br /> 0&0&0&0&1&1 - \lambda\\<br /> \end{array}<br /> \right]<br /> [/tex]
Finding the determinant yields:
[tex] -32 \lambda + 80\lambda^2 - 80\lambda^3 + 40\lambda^4 - 10\lambda^5 + \lambda^6[/tex]
Setting equal to zero and factoring gives the eigen values:
[tex] \lambda = <br /> \left[<br /> \begin{array}{cc}<br /> 0\\<br /> 2\\<br /> 2\\<br /> 2\\<br /> 2\\<br /> 2\\<br /> \end{array}<br /> \right][/tex]
Plugging in lambda = 2 into the lambda equation gives:
[tex] \left[<br /> \begin{array}{cc}<br /> 1&-1&1&1&0&0\\<br /> 1&-1&-1&-1&0&0\\<br /> 0&0&0&0&1&1\\<br /> 0&0&0&0&-1&-1\\<br /> 0&0&0&0&-1&1\\<br /> 0&0&0&0&1&-1\\<br /> \end{array}<br /> \right][/tex]
The columns help for the simultaneous equations:
The bottom four rows reveal that X5, X6 = 0
Adding the first two rows together gives:
2X1 - 2X2 = 0
or
X1 = X2, So I choose X1 = X2 = 1, since the eigen vector must be a non-zero vector.
X3 and X4 cancel out so I choose them to = 0.
Since the eigen values repeat, I have to use the previous eigen vector as the answer to the simultaneous equations:
Summing the top two rows together:
2X1 - 2X2 = 2
or
X1 = 1 + X2. Everything else is still zero, choose X2 = 0, X1 = 1
Recursively using the previous eigen vector:
2 equations, 4 unknowns, choose X2 = 0, X4 = 0, top two equations become:
X1 + X3 = 1
X1 - X3 = 0
X1 and X3 = 1/2
This is where the trouble comes into play:
3rd equation : X5 + X6 = 1/2
4th equation: -X5 - X6 = 0
which cannot be solved...
This keeps happening over and over. I used MATLAB to verify that the eigen values and vectors could be found...but I cannot solve this through.
Any suggestions?
Your problem is in the block form
[itex][\begin{array}{cc}A&B\\0&C\end{array}][\begin{array}{c}x_1\\x_2\end{array}]=\lambda[\begin{array}{c}x_1\\x_2\end{array}][/itex]
which is
[itex]Ax_1+Bx_2=\lambda x_1[/itex]
[itex]Cx_2=\lambda x_2[/itex]
which you can solve easier because they are 3x3
A few more questions (forgive my lacking linear algebra skills)
1) You say that the problem was in a special form...why does this method present itself due to the form? Does it not apply if the lower-left 3x3 was not equal to zero?
2) are x1 and x2 both going to be 3x3 matrices, and concatenated together into a 3x6 will be the eigen vectors?
3) In terms of solving for x1 and x2, is this just simultaneous matrix equations, so perform the usual simultaneous-equation solving skills (with inverse matrices instead of division)?
4) Was it just very difficult (or impossible) to solve it the way I had described, due to the fact that I get too much freedom to choose many of the values, and end up getting stuck during the process if I'm not very strategic?
1) The lower-left block being 0 makes the second equation that I gave simpler, otherwise the two equations will be coupled, and not easy to solve by hand. It is just a trick that you play to make a homework (not real life) problem simpler.
2) x1 and x2 are both 3x1 vectors, they concatenate to a 6x1 vector that is the eigenvector, there are multiple solutions, but I recommend that you treat them as vectors not matrices, and find out all the vectors that satisfy the equations.
3) The second equation is a 3x3 eigenvalue problem, solve as you did for the 6x6 problem, only much simpler (by hand); then sub into the first equation and solve as a linear system (also 3x3, try to find all the solutions, whatever way you prefer)
4) Honestly I didn't read your description, but eigenvalue problems are hard problems, usually handled by computers, any general form beyond 6x6 is probably too much for a human :)(unless it has special structures, such as convolution matrix, etc. )
Alright, well here's how far I got:
[tex] |C - \lambda I| = (2-\lambda)(-2\lambda + \lambda^2)[/tex]
So the eigen values for the C Matrix are 2, 2, and 0.
I won't show the exact steps, but my eigen vectors (x2) for C are:
[tex] \left[<br /> \begin{array}{cc}<br /> 0\\<br /> 1\\<br /> -1\\<br /> \end{array}<br /> \right][/tex]
[tex] \left[<br /> \begin{array}{cc}<br /> 1\\<br /> 0\\<br /> 0\\<br /> \end{array}<br /> \right][/tex]
[tex] \left[<br /> \begin{array}{cc}<br /> 0\\<br /> -\frac{1}{2}\\<br /> -\frac{1}{2}\\<br /> \end{array}<br /> \right][/tex]
Solving the first equation for x1:
[tex] x1 = (A-\lambda I)^{-1} (-B x2)[/tex]
but now the problem is that when I plug in 2 for lambda, I end up with a matrix that I cannot take the inverse of.
Any suggestions on moving forward??
I think you're a bit confused. The whole point of eigenvalues is that those are the values which, when you plug in for lambda, you get a non-invertible matrix. Let's look at a smaller example to see how to find the corresponding eigenvector. Given the matrix
[tex]\left( \begin{array}{cc}1&1\\0&0\end{array} \right)[/tex]
You can check that it has eigenvalues of 0 and 1. Let's find the eigenvector corresponding to 1:
[tex]\left( \begin{array}{cc}1&1\\0&0\end{array} \right) \left( \begin{array}{cc} x\\ y \end{array} \right) = 1*\left( \begin{array}{cc} x\\ y \end{array} \right)[/tex]
This gives us two equations: x+y=x and 0+0=0. So the "solution" to this system of equations is y=0 and x can be anything. In general you won't get a unique solution, because if v is an eigenvector, you can scale v to get another eigenvector. So you expect to get a one dimensional set of solutions
Okay. I see. You're right I was confused about the eigen-vectors creating a non-invertible matrix.
The example you described was the original method I was trying to do, but got stuck with impossible to solve system of equations (on the 4th repeated eigen-value "plug-in", see first post)
Following sunjin's suggestion of partitioning the matrix and creating linear system to solve, I got stuck on not being able to take the inverse (because of what you just told me about eigen-vectors).
Sooooo...is there a different way to solve that linear system..is there a different way to do the original approach of simultaneous equations...or is there another method altogether??
If you row-reduce your matrix a bit more, you get
\begin{bmatrix}
1&-1&0&0&0&0\\
0&0&1&1&0&0\\
0&0&0&0&1&0\\
0&0&0&0&0&1\\
0&0&0&0&0&0\\
0&0&0&0&0&0\\
\end{bmatrix} which corresponds to the four equations
\begin{align*}
x_1 - x_2 &= 0 \\
x_3+x_4 &= 0 \\
x_5 = 0 \\
x_6 = 0
\end{align*} You analyzed the first, third, and fourth equations already and found one eigenvector from this system, but there's a second one. From the first eigenvector, you had (1,1,0,0,0,0), (1,0,0,0,0,0), and (1/2,0,1/2,0,0,0). The fact you couldn't find a solution using the last vector in the chain means you've reached the end. Now you have to find a new chain starting with the second eigenvector.
Okay, I continued forward by doing the reduced-row echelon form, and now I am verifying my answers.
When I multiply the original A matrix by the eigenvector (1,0,0,0,0,0), I get an answer of (3,1,0,0,0,0)...Shouldn't the answer be a scalar multiple of the eigenvector? Does this mean I've made a mistake?
The matrix A doesn't have five linearly independent eigenvectors corresponding to the eigenvalue 2; it has only two, which you can find by solving the original system (A-λI)x=0.
The vector (1,0,0,0,0,0) is a generalized eigenvector of A. You found it by solving (A-λI)x = (1,1,0,0,0,0)T so you have Ax = (1,1,0,0,0,0)T + λx = (3,1,0,0,0,0)T.
Great! So that means everything is gravy now!
Thanks all, this has REALLY given me a lot of insight on some of these concepts. :)
