Solve for x log3 (x-2) + log3 (x-4) = 7
  • Thread starter nae99
41 replies · 9K views · last reply
nae99
i have been trying to do this ques. 2 days now and still can't get the ans.
help please
Solve for x
log3 (x-2) (x-4) = 7
A reply from another thread:
Bassalisk said:
This is trivial stuff in my opinion. Domain x>4. (x-2)*(x-4)=3^7. well rest is...
help please
Solve for x
nae99 said:
what does that mean
His hint was to use the inverse function of the logarithm as your first step.
So if you were working with log base 2, you would raise both sides to the exponent power of 2...
[tex]log_2 (x) = 5[/tex]
[tex]2^{log_2 (x)} = 2^5[/tex]
...and simplify the lefthand side...
i would then prolly do this
x^2-4x-2x-8 = 3^7
x^2- 6x- 8 = 3^7
am i on the right track
x^2-4x-2x-8 = 3^7
x^2- 6x- 8 = 3^7
There's a sign error in your multiplication of (-2)*(-4), but other than that...
x^2 - 6x + 8 = 3^7
x^2 - 6x + 8= 2187
is that good
Looks good. Now solve for x.
And once you solve for x, use your scientific calculator to check your answer by plugging it back into your original problem statement in Post #1.
x^2 - 6x + 8= 2187
x^2 - 6x +8 - 2187 =0
x^2 - 6x - 2179 =0
x = - 6 [itex]\pm[/itex] [itex]\sqrt{}[/itex] 6^2 - 4*1*2179[itex]/[/itex] 2*1
x = - 6 ± [itex]\sqrt{}[/itex] 36 - 8716 [itex]/[/itex] 2*1
x = - 6 ± [itex]\sqrt{}[/itex] -8680 [itex]/[/itex] 2
x = -6 ± 93.167[itex]/[/itex] 2
x = -6 + 93.167[itex]/[/itex] 2
x = 87.167 [itex]/[/itex] 2
X = 4.436
how is that so far
nae99 said:
x^2 - 6x + 8= 2187
x^2 - 6x - 2179 =0
X = 4.436
how is that so far
You tell us. Is the answer correct when you plug it into the original equation in Post #1?
EDIT -- I do think I see a sign error in the first line where you apply the Quadratic Formula, though...
nae99 said:
i don't know how to plug it into the equation
First, fix the sign error(s) in the Quadratic Equation application, and then, do you have a scientific calculator that let's you do log base n?
that link does not work and what error is in the eqaution
The link works fine when I click on it. But in any case, all you have to do is Google logarithm calculator, and you get lots of useful links (inclucding that one).
You have two sign errors that I think I see in your application of the Quadratic Equation. Just be careful in handling negative signs, and re-check the line where you substitute A, B and C into the Quadratic Equation...
the mistake that I am seeing is here:
x = -6 ± 93.167/ 2
it should have been
x = -6± -93.167/ 2
but i keep looking where i make the mistake when i substitute A B C but i can't recognize it
x = -6 ± 93.167/ 2
it should have been
x = -6± -93.167/ 2
What is the value of B? What is the Quadratic Formula in terms of A, B and C? What is the sign of C? Did it get propagated into the last term in the numerator inside the square root?
nae99 said:
the value of B=6
nae99 said:
and C is 2179
No.
The equation that you ended up with was:
x^2 - 6x - 2179 =0
Look again at the definition of the Quadratic Formula. Are there minus signs in the definition?
i am confuse...so are you saying that i should change the minus to plus
What do you think?
If you had an equation x = 5 - y, and I told you y = -5, what would x be?
nae99 said:
x^2 - 6x - 2179 =0
[tex]x=\frac{-b\pm\sqrt{b^2-4ac}}{2a}[/tex]
a = 1, b = -6, c = -2179
So, you made a sign errors when plugging in both b and c .
:smile: oh i see ok. so it should be;
x = -(-6) [itex]\pm[/itex] [itex]\sqrt{}[/itex] -6^2 - 4*1*-2179 [itex]/[/itex] 2*1
