Solve log5(x-1) + log5(x-2) - log5(x+6) = 0
  • Thread starter Thread starter Acnhduy
The equation log5(x-1) + log5(x-2) - log5(x+6) = 0 can be solved using logarithmic properties and the quadratic formula. The initial steps involve combining the logarithmic terms to form log5[(x-1)(x-2)/(x+6)] = 0, leading to the quadratic equation x² - 4x - 4 = 0. This quadratic does not factor neatly, necessitating the use of the quadratic formula to find its roots. It is crucial to verify the solutions by substituting them back into the original logarithmic equation to ensure they yield valid results.
  • Understanding of logarithmic properties, specifically log(a) + log(b) = log(ab)
  • Familiarity with solving quadratic equations
  • Knowledge of the quadratic formula: x = (-b ± √(b²-4ac)) / 2a
  • Ability to check the validity of solutions in logarithmic contexts
  • Study the properties of logarithms in depth, focusing on their applications in solving equations
  • Practice solving quadratic equations using the quadratic formula and completing the square
  • Learn about the implications of extraneous solutions in logarithmic equations
  • Explore advanced topics in algebra, such as polynomial roots and their graphical representations
Students studying algebra, particularly those tackling logarithmic equations and quadratic functions, as well as educators seeking to reinforce these concepts in a classroom setting.
Acnhduy
Solve:
I feel like this is really simple but I cannot get the answer.
This is what I attempted
Since they have the same base, I multiplied the top
log5[(x-1)(x-2)] - log5(x+6) = 0
This gives me
log5(x2-3x+2) - log5(x+6) = 0
At this point I did not now what to do, I tried 2 methods,
1.
Since they are the same base again, I divided the top this time
log5(x2-3x+2) / (x+6) = 0
but I don't know how to continue
2.
I moved - log5(x+6) to the other side
log5(x2-3x+2) = log5(x+6)
Since they have the same base I ignored them so
x2-3x+2 = x+6
Which gave me
x2 - 4x - 4
Which cannot be factored.
Please help, thankyou :)
What you've done is incorrect because the rule of logarithms is
\log{a}+\log{b} = \log{ab}
But
a^m\cdot a^n = a^{m+n}\neq a^{mn}
See if you can apply these algebraic formulae to correctly answer your question.
I did use this logarithm law, since the base for all of them are common.
This gives me
But
I did not use at all throughout. I am not sure where I have gone wrong, can you point it out for me?
What is
\log{a^m}+\log{a^n}
equivalent to?
Oh, I think I found the problem... 5 is the base, not 10.
So this is the correct equation:
Terribly sorry, would my calculations be correct following the equation above?
Oh, in that case, you're on the right track in #2 in your first post. x^2-4x-4=0 cannot be factored in the manner you're thinking of, but it does have irrational roots. Use the quadratic formula to find them.
Also, keep in mind that some (or even all) of your x solutions might not be valid. You need to plug them back into the original equation to see if it makes sense. If you end up with log(-1) for example, then that solution of x needs to be scrapped.
Acnhduy said:
Solve:
x2-3x+2 = x+6
Which gave me
x2 - 4x - 4 = ??
What is x2 - 4x - 4 equal to?
It should be a quadratic equation, can you solve it? The roots need not be integer numbers!
ehild
Oh I see, thank you!
x2 - 4x - 4 = 0
When you mean that they do not need to be intergers, how do I go about solving? As suggested by Mentallic, I would have to use the quadratic formula right?
The quadratic formula is the easiest method, but completing the square works too if you don't remember the formula.
x^2-4x-4=0
Now add 4 to both sides.
(x^2-4x+4)-4=4
(x-2)^2-4=4
etc.
This is how the quadratic formula is derived. Begin with
ax^2+bx+c=0
and then complete the square to solve for x.
10K
  • · Replies 17 ·
  • · Replies 24 ·
