Solve System of Diff Eqns Mistake: Find Answer
  • Thread starter Thread starter frggr
    System
8 replies · 3K views
frggr
I'm not sure where I am making the mistake was hoping you guys could help.
Q:
x' = 3x - 2y; x0=1
y' = 3y - 2x; y0=1
My Sol:
1) Take Laplace Transform of both sides.
X:=L{x}, Y := L{y}
Xs - x0 = 3X - 2Y
Ys - y0 = 3Y - 2X
Xs - 1 = 3X - 2Y
Ys - 1 = 3Y - 2X
Xs - 3X = 1 - 2Y
Ys - 3Y = 1 - 2X
(s-3)X + 2Y = 1 Eqn 1
(s-3)Y + 2X = 1 Eqn 2
2Eqn 1 - (s-3)Eqn 2
2(s-3)X + 4Y - (s-3)2Y - 2(s-3)X = 2 - (s-3)
[4 - (s-3)2]Y = 2 - s + 3
Y = -(s - 5) / [4 - (s-3)2]
Y = (s - 5) / [(s-3)2 - 4]
Y = (s - 3) / [(s-3)2 - 4] - 2 / [(s-3)2 - 4]
L-1{Y} = L-1{(s - 3) / [(s-3)2 - 4]} - L-1{2 / [(s-3)2 - 4]}
These are sin and cos shifted by 3, so Sin and cos times ee3t
y = e3tcos(-2t) - e3tsin(-2t)
y = e3tcos(2t) + e3tsin(2t)
(s-3)Y + 2X = (s-3)X + 2Y
(s-5)Y = (s-5)X
Y = X :. y=x
y = x = e3tcos(2t) + e3tsin(2t)
Answer SHOULD BE
y = x = et
Which does make sense because when plugged into originial eqn et works, where as my answer does not.
Y = (s - 5) / [(s-3)² - 4] (OK)
Better simplify !
(s-3)²-4 = (s-5)(s-1)
Y=1/(s-1)
welcome to pf!
hi frggr! welcome to pf! :smile:
frggr said:
x' = 3x - 2y; x0=1
y' = 3y - 2x; y0=1
i assume you wanted to practise Laplace Transforms, but if you just want a quickie solution, just looking at those equations immediately suggests that the obvious thing to do is to write out x' + y' and x' - y' :wink:
thank you both for the reply, and yea I was just trying to get practice with Laplace transforms.
Better simplify
Y=1/(s-1)
Heh, guess I shouldn't have missed that. Question now is why did my solution come out wrong? -- Simplifying shouldn't really change the outcome just how difficult it is to get there right?
There are some mistakes in your Laplace inversions.
The inverse Laplace of 2/((s-3)²-4) is exp(3t)sinh(2t)
The inverse Laplace of (s-3)/((s-3)²-4) is exp(3t)cosh(2t)
Then exp(3t)cosh(2t)-exp(3t)sinh(2t) = exp(3t)exp(-2t) = exp(t)
So, the outcome is the same.
I'm more lost now than when I started. -> I must be doing Laplace transforms completely wrong. Or am using the wrong definition to calculate them because :
I tried computing exp(3t)sin(2t) by definition and got 2/((s-3)^2-4), Any explanations would be appreciated
I've supplied my calculations below
Laplace Transform of exp(3t)sin(2t):
[tex] I = \int_{0}^{\infty } e^{-st}f(t)dt[/tex][tex] I = \int_{0}^{\infty } e^{-st} / e^{3t}sin(2t)dt[/tex][tex] I = \int_{0}^{\infty } e^{(3-s)t}sin(2t) dt[/tex][tex] I = \int _{0}^{\infty }e^{-(s-3)t}sin(2t)[/tex]
Calculating the integral:
[tex] I = \int_{0}^{\infty } e^{-s^*t}sin(-2t)dt \therefore -I = \int_{0}^{\infty } e^{-s^*t}sin(2t)dt,\ \ where\ \ s^* = s-3[/tex]
[tex] u = e^{-s^*t} \ \ du =-s^*e^{-s^*t}dt[/tex]
[tex] dv = sin(2t)dt\ \ v = -\frac{1}{2} cos(2t)[/tex]
[tex] \therefore -I =-e^{-s^*t}\frac{1}{2} cos(2t)]_{0}^{\infty} + \frac{-s^*}{2} \int_{0}^{\infty}cos(2t)e^{-s^*t}[/tex]
[tex] u = e^{-s^*t}\ \ du=-s^*e^{-s^*t}dt [/tex]
[tex] dv = cos(2t) \ \ v = \frac{1}{2}sin(2t)[/tex]
[tex] \therefore -I = [-\frac{1}{2}e^{-s^*t} cos(2t)]_{0}^{\infty} - [\frac{-s^*}{4}e^{-s^*t}sin(2t)]_{0}^{\infty} +\frac{s^*^2}{4} I[/tex]
[tex] \therefore \frac{s^*^2 - 4}{4}I = [0 + \frac{1}{2}] -[0 - 0] [/tex]
[tex] I =\frac{4}{s^*^2 - 4} * \frac{1}{2} = \frac{2}{s^*^2 - 4} = \frac{2}{(s-3)^2 - 4}[/tex]
Laplace Transform of exp(3t)sin(2t) isn't 2/((s-3)-4)
it's 2/((s-3)²+4)
it's 2/((s-3)²+4)
Ahh, thanks.
Not sure why I thought (-2)^2 would be -4. My bad.
Do have one last question though I don;t really care if it's answered.
Would
e^(3t) cos(2i) + i e(3t)sin(2i) be a valid solution, or are Laplace transforms only defined for Real Numbers?
I suppose that your question is about
y = e^(3t) cos(2it) + i e^(3t)sin(2it)
If so, y = e^(3t)*(cos(2it)+i*sin(2it))
y = e^(3t)*e^(i*2it) = e^(3t)*e^(-2t)
y = e^t which is a valid solution
Another way :
cos(2it) = cosh(2t)
sin(2it) = i sinh(2t)
