Solve System of Diff Eqns Mistake: Find Answer
  • Thread starter Thread starter frggr
    System
The discussion revolves around a system of differential equations involving Laplace transforms. The original poster presents a set of equations for x' and y' with initial conditions, and attempts to solve them using Laplace transforms but encounters difficulties in their calculations and simplifications.
  • The original poster attempts to apply Laplace transforms to the system of equations but questions the validity of their results after simplification. Other participants suggest alternative approaches and corrections to the Laplace inversions.
Participants are actively engaging in clarifying the original poster's misunderstandings regarding Laplace transforms and their inversions. Some guidance has been provided regarding the correct forms of the Laplace transforms, and there is an exploration of the implications of complex numbers in the context of the transforms.
There are indications of confusion regarding the definitions and calculations of Laplace transforms, particularly in relation to complex numbers and the original equations. The original poster expresses uncertainty about their approach and the impact of simplifications on the outcomes.
frggr
I'm not sure where I am making the mistake was hoping you guys could help.
Q:
x' = 3x - 2y; x0=1
y' = 3y - 2x; y0=1
My Sol:
1) Take Laplace Transform of both sides.
X:=L{x}, Y := L{y}
Xs - x0 = 3X - 2Y
Ys - y0 = 3Y - 2X
Xs - 1 = 3X - 2Y
Ys - 1 = 3Y - 2X
Xs - 3X = 1 - 2Y
Ys - 3Y = 1 - 2X
(s-3)X + 2Y = 1 Eqn 1
(s-3)Y + 2X = 1 Eqn 2
2Eqn 1 - (s-3)Eqn 2
2(s-3)X + 4Y - (s-3)2Y - 2(s-3)X = 2 - (s-3)
[4 - (s-3)2]Y = 2 - s + 3
Y = -(s - 5) / [4 - (s-3)2]
Y = (s - 5) / [(s-3)2 - 4]
Y = (s - 3) / [(s-3)2 - 4] - 2 / [(s-3)2 - 4]
L-1{Y} = L-1{(s - 3) / [(s-3)2 - 4]} - L-1{2 / [(s-3)2 - 4]}
These are sin and cos shifted by 3, so Sin and cos times ee3t
y = e3tcos(-2t) - e3tsin(-2t)
y = e3tcos(2t) + e3tsin(2t)
(s-3)Y + 2X = (s-3)X + 2Y
(s-5)Y = (s-5)X
Y = X :. y=x
y = x = e3tcos(2t) + e3tsin(2t)
Answer SHOULD BE
y = x = et
Which does make sense because when plugged into originial eqn et works, where as my answer does not.
Y = (s - 5) / [(s-3)² - 4] (OK)
Better simplify !
(s-3)²-4 = (s-5)(s-1)
Y=1/(s-1)
welcome to pf!
hi frggr! welcome to pf! :smile:
frggr said:
x' = 3x - 2y; x0=1
y' = 3y - 2x; y0=1
i assume you wanted to practise Laplace Transforms, but if you just want a quickie solution, just looking at those equations immediately suggests that the obvious thing to do is to write out x' + y' and x' - y' :wink:
thank you both for the reply, and yea I was just trying to get practice with Laplace transforms.
Better simplify
Y=1/(s-1)
Heh, guess I shouldn't have missed that. Question now is why did my solution come out wrong? -- Simplifying shouldn't really change the outcome just how difficult it is to get there right?
There are some mistakes in your Laplace inversions.
The inverse Laplace of 2/((s-3)²-4) is exp(3t)sinh(2t)
The inverse Laplace of (s-3)/((s-3)²-4) is exp(3t)cosh(2t)
Then exp(3t)cosh(2t)-exp(3t)sinh(2t) = exp(3t)exp(-2t) = exp(t)
So, the outcome is the same.
I'm more lost now than when I started. -> I must be doing Laplace transforms completely wrong. Or am using the wrong definition to calculate them because :
I tried computing exp(3t)sin(2t) by definition and got 2/((s-3)^2-4), Any explanations would be appreciated
I've supplied my calculations below
Laplace Transform of exp(3t)sin(2t):
[tex] I = \int_{0}^{\infty } e^{-st}f(t)dt[/tex][tex] I = \int_{0}^{\infty } e^{-st} / e^{3t}sin(2t)dt[/tex][tex] I = \int_{0}^{\infty } e^{(3-s)t}sin(2t) dt[/tex][tex] I = \int _{0}^{\infty }e^{-(s-3)t}sin(2t)[/tex]
Calculating the integral:
[tex] I = \int_{0}^{\infty } e^{-s^*t}sin(-2t)dt \therefore -I = \int_{0}^{\infty } e^{-s^*t}sin(2t)dt,\ \ where\ \ s^* = s-3[/tex]
[tex] u = e^{-s^*t} \ \ du =-s^*e^{-s^*t}dt[/tex]
[tex] dv = sin(2t)dt\ \ v = -\frac{1}{2} cos(2t)[/tex]
[tex] \therefore -I =-e^{-s^*t}\frac{1}{2} cos(2t)]_{0}^{\infty} + \frac{-s^*}{2} \int_{0}^{\infty}cos(2t)e^{-s^*t}[/tex]
[tex] u = e^{-s^*t}\ \ du=-s^*e^{-s^*t}dt [/tex]
[tex] dv = cos(2t) \ \ v = \frac{1}{2}sin(2t)[/tex]
[tex] \therefore -I = [-\frac{1}{2}e^{-s^*t} cos(2t)]_{0}^{\infty} - [\frac{-s^*}{4}e^{-s^*t}sin(2t)]_{0}^{\infty} +\frac{s^*^2}{4} I[/tex]
[tex] \therefore \frac{s^*^2 - 4}{4}I = [0 + \frac{1}{2}] -[0 - 0] [/tex]
[tex] I =\frac{4}{s^*^2 - 4} * \frac{1}{2} = \frac{2}{s^*^2 - 4} = \frac{2}{(s-3)^2 - 4}[/tex]
Laplace Transform of exp(3t)sin(2t) isn't 2/((s-3)-4)
it's 2/((s-3)²+4)
it's 2/((s-3)²+4)
Ahh, thanks.
Not sure why I thought (-2)^2 would be -4. My bad.
Do have one last question though I don;t really care if it's answered.
Would
e^(3t) cos(2i) + i e(3t)sin(2i) be a valid solution, or are Laplace transforms only defined for Real Numbers?
I suppose that your question is about
y = e^(3t) cos(2it) + i e^(3t)sin(2it)
If so, y = e^(3t)*(cos(2it)+i*sin(2it))
y = e^(3t)*e^(i*2it) = e^(3t)*e^(-2t)
y = e^t which is a valid solution
Another way :
cos(2it) = cosh(2t)
sin(2it) = i sinh(2t)
  • · Replies 25 ·
