Solve system with rational expressions in x and y
4 replies · 2K views · last reply
Hivoyer
The system is declared as follows:
8/(2*x - y) - 7/(x + 2*y) = 1
4/((2*x - y)^2) - 7/((x + 2*y)^2) = 3/28
I define 'x' to equal k*y and I replace it inside the equation:
8/(2*k*y^2) - 7(k*y + 2*y) = 1
4(4*k^2*y^2 - 4*k*y^2 + y*2) - 7(k^2*y^2 + 4*k*y^2 + 4*y^2) = 3/28
I know I have to divide the top one by the bottom one and take y^2 out of the brackets, however the way it is now, it would become impossibly complex if I divide them.How can I simplify them before I divide?Not sure how to proceed.Using least common multiple also results in a monstrosity.
How do you get 2ky^2 if you replace x with ky in 2x - y?
What happens to the fractions in equation 2?
I doubt that this will work.
I would substitute 2x-y and x+2y with new parameters, and get rid of the denominators quickly.
By doing that I get:
8*v - 7*u = u*v
12*v^2 - 196*u^2 = 3*u^2*v^2
I can't use any of them to express u = # or v = # :(
8*v - 7*u = u*v
First, shouldn't the ##12v^2## in your second equation be ##112v^2##? (Probably just a typo)
Second, I suggest manipulating the first equation to get ##u = \frac{8v}{v+7}##(assuming that ##v \neq -7##, you should check that this cannot be true by substituting ##v = -7## into the system). Then, as mentioned above, substitute this expression into the second equation and solve for v.
