Why Does the Swimming Angle Calculation Depend on Trigonometric Functions?
  • Thread starter Thread starter Fused
The discussion centers on understanding the trigonometric calculations involved in a swimming problem where a swimmer must account for river current. The swimmer's speed in still water is 0.45 m/s, and the river current is 0.40 m/s, leading to confusion over the correct angle to aim upstream. One participant calculated the angle using inverse sine, while another argued for inverse cosine, leading to complementary angles of 62.74 degrees and 27.3 degrees, respectively. Both methods ultimately yield the same time to cross the river, approximately 363.8 seconds, but highlight different approaches to visualizing the problem. The conversation emphasizes the importance of correctly interpreting angles in relation to the swimmer's path and the riverbank.
Fused
I did the problem, got the correct answer but dont' know why I was supposed to do it this way! Please help me understand the reasoning behind all this:
A swimming is capable of swimming .45m/s in still water. She is swimming across a 75 m wide river whose current is .40 m/s. A) at what upstream angle must the swimmer aim if she is to arrive at a poitn directly across the stream? B) How long would it take her?
I drew a picture and set the x and y components separately. So V being velocity, WL = water with respect to Land, SL swimmer respect to land, and SW swimmer respect to water .. I got
Vwlx= 0 Vslx = ? Vswx = ?
Vwly = .4 Vsly = 0 Vswy = ?
A) to find the angle I took the inverse sin of .40/.45 to get 62.74 . However doesn't this depend on the picture? The way my profesor explained it, he drew it so that it would be inverse cos .. BEcause this confused me I drew it differently so that inverse sin would make sense. According to the drawing, the answer shouldn't be different but then why does it seem like it should be?
B) then I took Vswy = VwLy + VsLy to get
Vswy = .40 + 0 = .4 < this I understand
.4 = .45sin(angle) << this I do not. Why do we set this up this way?
Inv sin (.4/.45) =angle
62.74 degrees ..
then to get the x component <<again, I don't understand why we set this up this way.
Vswx = .45cos(62.74)
Vswx = .206
distance formula:
D=VT
75= .206t
75/.206 = t
t= 363.8 s
Any help would be appreciated.
Before you read this post, please be forewarned that this is coming from a 15-year-old who has not been taught or self-learned relative velocities. I'm posting to bump your thread, and also to seek help for myself.
I'm thoroughly confused by your working. I intuitively feel that your professor was right, and that you should take the inverse cos. I would say that the answer to (A) would be cos-1(0.4/0.45) = 27.3 degrees.
I used the Pythagorean Theorem for (B). With x as the speed of the total effort crossing the river (bank to bank), which is the speed at which the swimmer appears to be crossing the river because to our eyes the swimmer is swimming directly from bank to bank without deviation,
x2 + 0.42 = 0.452
x = 0.206155281 m/s
So the total time taken to cross the river is 75/0.206155281 = 363.8034376 seconds.
Your final answer was correct because you took a short cut. Unfortunately this led to your first answer being wrong.
To quote the problem
Fused said:
62.74 degrees ..
Your angle is complimentary to mine, so maybe you did it the other way.
Here's the way I see the situation
http://myfiles.dyndns.org:8080/math/swim_across_river.jpg
It's 75m across, the river flows 0.4m/s to the right, the swimmer is going 0.45 to the left at angle theta based on the shore (did you base your angle off the normal instead?).
Horizontal speeds (finding the angle):
V_x = 0 = 0.4 - 0.45 \cos(\theta)
\cos(\theta) = \frac{0.4}{0.45}
\theta = 27.266
Then finding vertical speed:
V_y = 0.45 \sin(\theta)
V_y = 0.20615
Then the time:
t = \frac{75}{0.20615}
time = 363.809852 seconds
Looks like I get the same answer
My angle is between the shore and the swimmer. Your angle is between the swimmer and an imaginary line perpendicular to the shore. No problem doing it that way; it's just weird. :wink:
You may have a look at something I just scanned here:
Code:
[PLAIN]http://photos1.blogger.com/img/10/1553/1024/rivercrossing.jpg
[/PLAIN]
Copy and paste the address in the address bar for it to work. Thanks ShawnD!
And sorry for the atrocious handwriting!
recon, I can sort of understand what you're doing, but I'm too tired to figure it out.
For your link to work, it has to be manually copied and pasted into the address bar. Just clicking that link gives a 403 error.
thank you both!
18K
30K
31K
