Solving 1/y >= -2: why is the answer y <= -0.5?
  • Thread starter Thread starter cloud360
16 replies · 2K views
cloud360
solve
1/y>=-2
why is the answer y<=-0.5, with set notation: (-infinity,-0.5)
My solution:
1/y>=-2 (take y to other side)
1>=-2y (divide by -2 and flip symbol)
-1/2<=y
y>=-0.5
buy this is wrong according to my teachers solution
in your solution the first step you did was wrong,
from
1/y>=-2
u can't do
1>=-2y
from
1/y>=-2
u can't do
1>=-2y
why. i don't understand, can you pelase explain?
if you divide by a negative you change the symbol. but in my first part, i am not diving by a negative !
but can you explain why you can't go from
1/y>=-2
to
1>=-2y
Because y might be negative. If y is positive, then your reasoning works to conclude that y >= -0.5 (certainly true because we assumed y is positive to begin with). So what are the solutions to the inequality if y is positive? If y is negative, then your reasoning fails (why?)
how come you DO NOT changing symbol when dividing 1 by -2 ! see bold part. why is my symbol changing wrong
-1/2<=y
y>=-0.5
I don't understand. You are flipping the symbol, which is what you are supposed to do, because you are dividing by a negative number on both sides.
so if my flipping symbol is correct. then answer must be
y>=-0.5
No, because the part vishal pointed out was incorrect was actually the jump between the two bolded statements below:
-1/2<=y
y>=-0.5
-1/2<=y
y>=-0.5
edit, made error:
how come you cannot do this. how come you can't mutiply by y?
e.g if i had 1/x>-2...wont i be able to mutiply by sides by x
If you had 1/x > -2, i.e. you renamed your variable, then you aren't dealing with y any more. You cannot multiply by y and keep the sign unchanged, because you do not know whether the solutions y you are looking for are positive or negative. If they are negative, your sign would need to be switched.
The best you can do is say, if y is positive, then a series of steps leads to these (positive) solutions (in your case, all positive numbers that are greater than -0.5). Then, you can say, if y is negative, another series of steps leads to these additional (negative) solutions.
so if the other side is negative. should i change the symbol.
because this question just can not be solved with the algebra i have been thought for last 7 years
You can multiply by y, but since you don't know the sign of y, you have to look at two cases: one where y < 0 and one where y > 0.
If y < 0,
1/y >= -2
==> 1 <= -2y (multiplying by y changes the inequality direction)
==> -1/2 >= y (dividing by -2 changes the inequality direction again)
or y <= -1/2
Now, if y > 0,
1/y >= -2
==> 1 >= -2y (multiplying by y does not change the inequality direction)
==> -1/2 <= y (dividing by -2 changes the inequality direction)
or y >= -1/2, but since we stipulated that y > 0, we have
y > 0
The net result is the set {y | y <= -1/2 or y > 0}
If y < 0,
1/y >= -2
or y <= -1/2
Now, if y > 0,
1/y >= -2
y > 0
EXCELLENT EXPLANATION !
ok, please can you kindly tell me...would i look at the 2 cases where the variable can be positive(+) or negative(-). if i had:
1)1/x>=-2
2)1/(x+1)>=-2
3)1/(y+1)>=positive 2
4)1/(y)>=positive 2
1. yes
2. yes
3. yes
4. yes
In short, whenever you multiply both sides of an inequality by a variable, you need to look at the two cases.
Mark44 said:
1. yes
2. yes
3. yes
4. yes
ok. i applied what you just thought me. but it isn't working for 1/(x+1)>=-2
my solution:
if x>0
===>1/(x+1)>=-2
===>x>=1.5
if x<0
===>1/(-x+1)>=-2
===>1>=-2x-2
===>3>=-2x
===>-1.5<=2x
===>x>=-1.5
the answer is wrong according to this website
http://www3.wolframalpha.com/input/?i=1/(x+1)>=-2
its very strange. the answer for x>0 worked out algebraically is always the answer for x<0 but with opposite symbol
For 1/(x + 1) >= -2, the two cases are x + 1 < 0 and x + 1 > 0. Those inequalities are equivalent to, respectively, x < - 1 and x > -1. Notice that we're not concerned with x + 1 = 0, because we would be dividing by zero.
