Solving 3^(2y+3) = 3^(y+5) for y
7 replies · 2K views · last reply
GodOfYou
Exponential Equation! -Stuck!-
1. 32y+3 = 3y+5
2y + 3 = y+5
2y = y+2
I really don't think I am doing this right, I am trying to find the value of Y. the answer is 2 but I don't know how to come up with the answer.
The progress looks great to me! The next step is to get all of the y-terms on one side of the equation. :smile:
GodOfYou said:
2y + y = 2 or 2y2 = 2
These two equations are not equivalent. Let us ignore the 2y2 = 2 for now. Your previous step left the equation at 2y = y + 2. Remember that if you add or subtract a value from one side of the equation, you have to do the same thing to the other side. Therefore, in the first equation in the quote you have 2y + y = 2, but this is not the same as 2y = y + 2 because you added one y to the left side but subtracted the y from the right side. If you add y to the left, then you must add y to the right, getting 2y + y = y + y + 2.
Instead of this, can you think of what to do to both sides of the equation that would result in having no y on the right side of the equation?
If [itex]b^x=b^y[/itex], then [itex]x=y[/itex]
Remove [itex]b[/itex] from both sides, and you're left with something quite a bit easier to solve.
This is good advice, but the OP has already done this. Take a closer look at the original post.
GodOfYou said:
So then would it be 2y + y = 2 or 2y2 = 2?
2y + y and 2y2 are very different expressions. The first is (obviously) 2y + y, which is the same as 2y + 1y; the second is 2y*y.
The distributive law says that a(b + c) = ab + ac, or equivalently, that (b + c)a = ba + ca. This second form looks a lot like 2y + 1y.
Ahh, sorry about that. I should have looked at the solution attempt more closely.
