Solving a 2kg Ball Collision Problem
  • Thread starter Thread starter kehwon
    Ball Collision
12 replies · 6K views · last reply
kehwon
A 2.0 kg ball moving with a speed of 3.0m/s hits, elastically, an identical stationary ball as shown. If the first ball moves away with angle 30 to the original path, determine
a) the speed of the first ball after the collision.
b) the speed and direction of the second ball after the collision
m1v1 + m2v2 = m1v1' + m2v2'
1/2 m1v1^2 + 1/2m2v2^2 = 1/2 m1v1'^2 + 1/2 m2v2'^2
X component:
v1 = v1' + v2' (since v2 is 0, and m's are equal)
Y component:
v1' = v2' (since v1 and v2 are 0 and m's are equal)
Because of this, does this mean that the angles should be equal as well?
I'm very confused about what I can deduce and assume from the identical mass of the balls..
It'd be great if someone could point me in the right direction. Thanks!
Vx= Vcos theta and simailry Vy= Vsint heta can be used here.
So then do I divide the two components?
Cuz I tried that,
using
X: m1(v1 - v1'cos30) = m2(v2'costheta - 0)
v1 - v1'cos30 = v2costheta
Y: m1(0 -v1'sin30) = m2(v2'sintheta - 0)
- v1'sin30 = v2'sin theta
IF I divide Y by X, I get
v1-v1'sin30 / -v1'cos30 = tantheta
Then I'm stuck again :S
Using conservation of energy,
v1 = v1'+v2'
with the combined X and Y component equations I've been trying to solve this and came up with several crazy dead-end solutions, using different trig identities..
Okay,
so I have
(v1 - v1')(v1+v1') = v2'^2
which I would liek to incorporate into the x component: v1 - v1'cos30 = v2'costheta, but the cos30 is getting in the way.
I also tried putting Y component, with v2' = v1'sin30 / sin theta into the X component...
Your two momentum equations have in them sin theta and cos theta. Can you see how to combine them in a way that eliminates theta?
can I square the two momentum equations? then somehow combine them into sin^2theta + cos^2theta = 1?
I'm having troubles linking the two. If I just add the two squard equations together, that makes sense since it would be like pythagorean theorem.
However, since theX componenti s v1 - v1'cos30 on the left side, square of that would be v1^2 - 2v1v1'cos30 + v1'^2...
