DaveC426913
2025 Award
- 24,701
- 9,112
- TL;DR
- How complex might the algorithm end up being to solve this colour-matching puzzle in an ideally minimal number of moves?
Just for fun (read as: staring at the ceiling trying to sleep), trying to figure out if there is a programmatic way to solve this colour-matching puzzle app on my phone.
It's called...
Here is a partially solved puzzle:
The dotted tiles are immovable, and serve as references. The undotted tiles can be swapped two at a time.
This is not a time challenge; it is a minimum-move challenge. i.e.: the fewer moves the better.
I was idly wondering whether there is a theoretical "perfect" game, by solving it with the minimum possible moves for a given starting configuration with no wasted moves. (Note that every move you make involves the displacement of two tiles, but normally only one is put in its final location).
A couple steps are involved - some are more engineering that logic - although much of it can be easier done in one's head than with physical automation.
0. Establish conventions:
Columns: A-G, Rows:1-9.
1. Identify the initial configuration.
Capture the colour of tile A1, tag it with its unique RGB value. Repeat 62 times (for this puzzle) all the way to G9.
eg:
[A1:000,000,255], [B1:000,060,255], ...
[A2: 060,000,255], [B2: 060,060,255], ...
... [G9: 255,255,0]
2. Find neighbours.
At first I did not see a problem here. I assumed that a neighbour could be identified by subtracting the RG and B values to two tiles. A small reminder means close neighbours. The smallest remainder of all means this is a neighbor. But it doesn't yet tell us which neighbour it is. It could be one of four.
Notice too, that - depending on the difficulty of the puzzle - the difference in tint between neighbours can be arbitrarily small. The whole puzzle might be cool pastels - and that means the RGBs might be so close that neighbours might be arbitrarily hard to distinguish mathematically.
I think there's a lot more logic here than I first thought.3. Sort.
Use a sorting algorithm that minimizes the number of swaps in the 63-cell dataset. Output a sequence of move instructions.
eg:
[F2 > E2],
[E3 > E9],
[E2 > ??]
I see a problem here too. In step 3, E2 is supposed to move - but its on longer there. It was inadvertently moved in step 1, to make room for F2.Hope I don't fall asleep too quickly tonight or I'll never figure this out.
It's called...
eg:
... [G9: 255,255,0]
2. Find neighbours.
eg:
[F2 > E2],
[E3 > E9],
[E2 > ??]
