MHB How Do You Solve the Initial Value Problem $y'+5y=0$ with $y(0)=2$?
The initial value problem defined by the differential equation $y' + 5y = 0$ with the condition $y(0) = 2$ is solved using the integrating factor method. The integrating factor is identified as $u(t) = e^{5t}$. By applying this factor, the solution is derived as $y(t) = 2e^{-5t}$, which satisfies the initial condition. This approach effectively demonstrates the application of integrating factors in solving first-order linear differential equations.
  • Understanding of first-order linear differential equations
  • Familiarity with integrating factors in differential equations
  • Knowledge of natural logarithms and exponential functions
  • Basic skills in solving initial value problems
  • Study the method of integrating factors in greater detail
  • Explore other types of first-order differential equations
  • Learn about the applications of exponential functions in differential equations
  • Investigate numerical methods for solving initial value problems
Students and educators in mathematics, particularly those focusing on differential equations, as well as professionals seeking to reinforce their understanding of initial value problems and integrating factors.
karush
MHB
$\tiny{1.5.7.19}$
\nmh{157}
Solve the initial value problem
$y'+5y=0\quad y(0)=2$
$u(x)=exp(5)=e^{5t+c_1}$?
so tried
$\dfrac{1}{y}y'=-5$
$ln(y)=-5t+c_1$
apply initial values
$ln(y)=-5t+ln(2)\implies ln\dfrac{y}{2}=-5t
\implies \dfrac{y}{2}=e^{-5t}
\implies y=2e^{-5t}$
We will return to your problem after a short review of what input of a function means. Let's suppose that $f(x)=x+3$. What is $f(3)$?
here $u(t)=exp(t)= e^{\int t \ dt}$
Surely you mean $u(t) = \mathrm{e}^t$, not $\mathrm{e}^{\int{t}\,dt}$...
In actuality, the integrating factor is $u(t) = \mathrm{e}^{5\,t}$...
