How Can I Solve This Differential Equation for Y?
The discussion centers on solving a differential equation for Y, given a specific form involving constants a, b, and c, and a function X(t). It clarifies that the equation is not a partial differential equation since differentiation occurs only with respect to t. The solution approach involves expressing the equation in terms of known functions and integrating, but the challenge arises from having two unknown functions with only one equation. A second relation for Y is introduced, involving a constant d and a known function O, which allows for substitution and simplifies the problem to a single unknown function. The conversation highlights the need for careful naming conventions in calculus to avoid confusion.
JulieK
I have the following differential equation
\frac{\partial}{\partial t}\left(\frac{a}{X}\right)+\frac{X}{b}\frac{ \partial Y}{\partial t}+\frac{c}{X}=0
where a, b and c are constants and X is a function of
t. I want to solve it for Y analytically (if possible) or numerically.
First, that's not really a partial differential equation because the only differentiation is with respect to the single variable, t. If X(t) is a known function of t, then \partial/\partial ta/X is also a known function of t- call it X'(t). Then your equation can be written
\frac{X}{b}\frac{dY}{dt}= -X'- C/X
\frac{dY}{dt}= (-X'- C/X)\frac{b}{X}= -\frac{X'X- C}{X^2}
and you solve for Y by integrating.b
If X(t) is a known function of t I would solve it easily. Unfortunately this is not the case.
Then all you can do is write
Y(t)= -\int\frac{XX'- C}{X^2}dt
Two unknown functions and one equation only is not enough. You need two equations.
Many thanks to you all!
To close the gap, I obtained a second relation
Y=\frac{d}{O}\left(X^{1/2}-O^{1/2}\right)
where d is a constant and O is a known function of t with
a closed analytical form.
I would be inclined to call ##\frac{d}{dt}(a/X(t))## something other than ##X'(t)##, which could be confused with ##dX/dt##. :-p
Y=\frac{d}{O}\left(X^{1/2}-O^{1/2}\right)where d is a constant and O is a known function of t with
Take the derivative w.r.t. t, then you can substitute for \frac{dY}{dt} in HallsofIvy's equation in Post #2. Now you have a differential equation in just one unknown function, X(t).
p.s. "d" is not the best name for a quantity in anything having to do with calculus :smile:
