Solving a logarithm equation without change of base
  • Thread starter Thread starter lionely
    Stuck
16 replies · 3K views
lionely
I have been trying to solve this problem all day, I have used up 3 pages and to no avail.
I don't think i should try and change the bases because of the way the book is set up changing bases is not until the next chapter. So I want to try and get it out without changing bases. Can someone give me a hint?
The question is number 8
My work is 3 pages of scratch work so it is hard to type out but all I have done is try to combine the logs shown into 2 separate logs for the base a and the base 10. I get stuck there since I can't remove the logs.
If the left hand side is [itex]\log_{a}(A) - \log_{10}(B)[/itex], what values do you have for [itex]A[/itex] and [itex]B[/itex]?
lionely said:
I got it down to A being (6/25) and B being 24
You have simplified too far; consider [tex]\log_a (6/25) - \log_{10}(24) = \log_a(24/100) - \log_{10}(24) = \log_a(24) - 2\log_a(10) - \log_{10}(24).[/tex]
You have $$\log_{a}(6/25)=\log_{10}24-2$$
Lets consider the -2 in the equation. What is ##\log_{10}0.01## equal to?
Chet
-2 is equal to log(0.01) [ I'm using Log for the base a , because I don't know Latex]
so Log(24) - 2Log(10) = log(0.01) + log 24
Now apply the product rule to log(0.01) + log (24). What do you get?
lionely said:
Log(24)- 2Log(10) = log(6/25)
So, now you have $$\log_{a}(6/25)=\log_{10}(6/25)$$
So, what is a equal to?
Chet
Oh I see it was just something simple as that . I was thinking I would have to remove the log in the end never thought that I would just have to compare the bases...
So it was really easy I was overthinking it.
Thank you so much .
a is 10.
lionely said:
I'm still lost because the bases are different.
Convert everything to ##\log_{10}##. There are standard formulas for converting logarithms between different bases.
OP said he was avoiding using that.
Right: I missed that.
Problem (8) is equivalent to solving ##\ \log_a(A)=\log_{10}(A) \ ## for a.
Suppose it had been equivalent to solve ##\ \log_a(A)=\log_{10}(A) \ ## for a, where A ≠ B . How would you do that without the change of base formula?
