Solving a set of nonlinear quadratic equations
The forum discussion centers on solving a set of nonlinear quadratic equations represented by the equation ϒϒ'C – ϒα = B, where ϒ is a column vector, C is a column vector, and α is a real scalar. Participants highlight the challenges of this equation, particularly when B is a nonzero column vector, and discuss the implications of the left-hand side being a real symmetric rank one matrix. The conversation emphasizes the need for clarity in the formulation of the equations and suggests that if B is not a scaled version of ϒ or the zero vector, the problem becomes significantly more complex.
  • Understanding of nonlinear quadratic equations
  • Familiarity with matrix algebra and eigenvectors
  • Knowledge of real scalar properties
  • Experience with mathematical problem formulation
  • Research methods for solving nonlinear quadratic equations
  • Explore eigenvector and eigenvalue concepts in matrix theory
  • Learn about symmetric matrices and their properties
  • Investigate numerical algorithms for nonlinear systems, such as Newton's method
Mathematicians, data scientists, and engineers dealing with nonlinear systems, as well as students studying advanced algebra and matrix theory.
Tilfani
I would like to solve this system, which is a sets of non linear quadratic equations, the system needed to be solved can be expressed in general as follow:
ϒϒ'C – ϒα = B
Where ϒ=(ϒ1,ϒ2,...ϒn)’ is a column vector and ϒ’ its transpose
C=(c1,c2,…,cn)’ and B=(b1,b2,…bn)’ are a columns vector
And α is a reel scalar
I would like to solve for ϒ, with approximatively about 30
Can someone propose me an algorihm/method to solve this system.
also a code to do it wil be very useful.
Bests
ϒ’ϒC – ϒα = B
Bests
Y' Y is a scalar, ##\vec Y \cdot \vec Y = |\vec Y|^2##. If you know the value of ##\vec Y \cdot \vec Y## (but don't know the components of ##\vec Y##), you can rewrite the equation above as a system of equations:
##\alpha Y_1 = \vec Y \cdot \vec Y - b_1##
##\alpha Y_2 = \vec Y \cdot \vec Y - b_2##
##\alpha Y_n = \vec Y \cdot \vec Y - b_n##
Divide both sides by ##\alpha## to get
##Y_1 = 1/\alpha (\vec Y \cdot \vec Y - b_1)##
##Y_2 = 1/\alpha (\vec Y \cdot \vec Y - b_2)##
##Y_n = 1/\alpha (\vec Y \cdot \vec Y - b_n)##
so we're dealing with real scalars here.
So your 'equation' is:
ϒϒ'C – ϒα = B
or
ϒϒ'C = ϒα + B
so you have a real symmetric rank one matrix on the Left Hand side (LHS).
The issue is that every possible c you can choose on the LHS gets mapped to zero or is an eigenvector (i.e. ϒ) or a linear combination of the two aforementioned things. So let's hope that B is either a scaled version of ϒ or else the zero vector. If your B is the zero vector, it should be pretty easy. Otherwise you have problems.
More issues: For starters, why write ϒα + B on the Right hand side... why not just write
##\propto ϒ##
ϒϒ'C – ϒα = B
or
ϒϒ'C = ϒα + B
##\propto ϒ##
B is nonzero column, there is a way to solve that?
then ##B \propto ϒ## or this is not an equation
B is a constant.
Tilfani said:
B is a constant.
I don't know what this means. Your original post, and a quick dimensional check say B is a a column vector.
What I am trying to tell you is your original post is analogous to
## 2 = 3##
or
## 2 = 3 +x##
for real ## x \geq 0##
this is not an equation. It is just wrong.
Yes i mean B is a constant column vector. Do you think that is wrong to?
You're not hearing me. It is one of the 3 options
option a)
## B = \mathbf 0##
option b)
##B \propto ϒ##
option c)
I have nothing more to say on the matter. Good luck.
Ok, please look at eq (2 19) page 8 on this link, this paper, maybe some thing wrong.
Portfolio Theory: Origins, Markowitz and CAPM Based Selection - Springer
PDFhttps://www.springer.com › document
Please provide the actual link to the document. The link you show is just to the Springer site.
Please find enclosed the document. Go to page 7 to see the original problem, the resolution of lagrangian (which may be wrong) lead to equation posted which is (2 19)
35K
