Solving ab = a + b: What are the Possible Answers?
  • Context: High School
  • Thread starter Thread starter Einstein's Cat
The discussion revolves around the equation ab = a + b, specifically seeking integer solutions. Participants explore various approaches to identify potential solutions and the conditions under which they exist.
  • Exploratory, Mathematical reasoning, Debate/contested
  • One solution proposed is a = b = 2, but participants question whether other integer solutions exist.
  • Some participants suggest solving for b in terms of a to explore conditions for b being an integer.
  • A participant introduces the expression b = a / (a - 1) and notes that b must be a multiple of a - 1.
  • Another participant argues that it is actually a that needs to be a multiple of a - 1 for b to be an integer.
  • There is a suggestion to test common integers in the equation to find solutions.
  • Participants discuss the implications of b being greater than 2 and the resulting constraints on a.
  • One participant critiques the limitation of testing integers only up to 10, suggesting a more general approach to the problem.
Participants express differing views on the conditions needed for integer solutions, particularly regarding the roles of a and b in the equation. No consensus is reached on the complete set of solutions or the implications of the conditions discussed.
Some participants note the lack of rigor in limiting integer tests to a specific range and suggest that broader cases should be considered. The discussion reflects various assumptions and interpretations of the equation without resolving them.
Einstein's Cat
There is the equation
ab = a + b (the solutions have to be integers)
A solution to this is a= b= 2.
What are other solutions? Are there other solutions?
Mathematics news on Phys.org
Why don't you solve for b in terms of a and think about what would be necessary for b to be an integer if a is?
One more.
blue_leaf77 said:
One more.
it would be that
b= a / (a - 1)
thus b has to be a multiple of a - 1
I assume that the other solution is a=b=0
No, it is ##a## that needs to be a multiple of ##a-1## in order for ##b## to be an integer!
what pairs of integers satisfy that? I can't for the life of me think of any!
Did you try to simply insert common integers into the equation?
You got one solution of a=b=2 from a^2=(a+a) which can be converted to a quadratic expression to factor right?
So prove it.
##a## being a multilple of ##a-1## means ##a=b\cdot (a-1)## and since ##a## is the greater number, ##b## has to be positive.
Can you show why ##b## cannot be greater than ##2##?
fresh_42 said:
So prove it.
if b is greater than 2, say 3, then a= 3a - 3. no integer satisfies this from 1 to 10 and has a gets bigger the 3 is a smaller proportion of a so it can be assumed that this is the case
Well, ... yes. But the restriction to numbers until ##10## lacks a bit of rigor. ##a=b(a-1) > 2(a-1) = 2a -2## and thus ##a<2## would be more general and also leaves you with the cases ##a \in \{0,1\}\, ##or## \, b \in \{0,1,2\}## which you can handle manually. Or you proceed along the lines @jedishrfu has pointed out in #7.
  • · Replies 23 ·
  • · Replies 19 ·
  • · Replies 21 ·
