brotherbobby
- 806
- 178
- Homework Statement
- Solve ##\boldsymbol{\mid x-3\mid+\mid x-2\mid=1}##
- Relevant Equations
- Given ##|x-a| = x-a## if ##x\ge a## but ##|x-a| = a-x## if ##x<a##.
Solution attempt (mine) : There are mainly three cases to consider.
(1) ##\boldsymbol{x\ge 3\; :}## Using the relevant equations given above, the problem statement reduces to $$x-3+x-2 = 1\Rightarrow 2x=6\Rightarrow \underline{x =3}$$. We accept this solution as it lies in the given range for this case (##x \ge 3##).
(2) ##\boldsymbol{2\le x<3\; :}## Using the relavant equations, the problem statement reduces to $$3-x+x-2=1\Rightarrow 1 = 1,$$ which is always true. Hene the whole domain is valid as an answer : ##\underline{2\le x<3}##.
(3) ##\boldsymbol{x<2\; :}## Using the relevant equations, the problem statement reduces to $$3-x+2-x = 1\Rightarrow 5-2x=1\Rightarrow 2x = 4\Rightarrow x = 2$$, which falls out of the current range and hence is rejected as a solution.
From the underlined answers above, we can say that the solution to the given problem is ##\boxed{2\le x\le 3\Rightarrow x \in [2,3]}##.
Issue : The text agrees with my answer, but solves the problem in a way which should result in a slightly different answer and not the correct one.
Solution (text) : I copy and paste the solution as it appears in the text below, annotated in places by me where I believe the author is incorrect.
Question : Is the text mistaken? An answer would be welcome.
