Solving an Inverse FT: ω0 = ∏/4, y(t) = p_4(t)sin(πt/4)?
  • Thread starter Thread starter jp1390
    Inverse
The discussion centers on solving an inverse Fourier transform (FT) problem where the user derives the expression for y(t) based on the given Y(ω). The user correctly identifies the relationship between the sinc function and the Fourier transform properties, ultimately concluding that ω0 = π/4. However, there is a discrepancy with the solution manual, which states that y(t) = (1/2)p₄(t)sin(πt/2). The user seeks clarification on whether their solution or the manual's answer contains an error.
  • Understanding of Fourier Transform properties
  • Familiarity with sinc functions and their applications
  • Knowledge of inverse Fourier Transform techniques
  • Basic skills in signal processing concepts
  • Review the properties of the Fourier Transform, specifically the modulation property
  • Study the derivation of the inverse Fourier Transform for sinc functions
  • Examine the implications of pulse duration on Fourier Transform results
  • Investigate common errors in Fourier Transform calculations and their resolutions
Students and professionals in signal processing, electrical engineering, and applied mathematics who are working with Fourier Transforms and seeking to deepen their understanding of inverse transformations and sinc functions.
jp1390
Hi, quick question regarding my solution of this Inv. FT:
[tex]Y(\omega) = \frac{1}{j}[sinc(\frac{2\omega}{\pi} - \frac{1}{2}) - sinc(\frac{2\omega}{\pi} + \frac{1}{2})][/tex]
Recognizing that that this looks a lot like this property of the FT:
[tex]x(t)sin(\omega_{0}t) \leftrightarrow \frac{j}{2}[X(\omega + \omega _{0}) - X(\omega - \omega _{0})][/tex]
Rearranging to get in that form, factoring out a -1, which = j*j:
[tex]Y(\omega) = \frac{2j^{2}}{2j}[sinc(\frac{2\omega}{\pi} + \frac{1}{2}) - sinc(\frac{2\omega}{\pi} - \frac{1}{2})] = 2\frac{j}{2}[sinc(\frac{2\omega}{\pi} + \frac{1}{2}) - sinc(\frac{2\omega}{\pi} - \frac{1}{2})][/tex]
[tex]x(t) = p_{\tau}(t) \leftrightarrow X(\omega) = \tau sinc(\frac{\tau \omega}{2\pi})[/tex] τ = 4 in this case
Knowing this information, we can find ω0:
[tex]Y(\omega) = (\frac{1}{2})\frac{j}{2}[4sinc(\frac{4}{2\pi}(\omega + \frac{\pi}{4})) - 4sinc(\frac{4}{2\pi}(\omega - \frac{\pi}{4}))][/tex]
Therefore ω0 = ∏/4... and y(t) is found to be:
[tex]y(t) = \frac{1}{2}p_{4}(t)sin(\frac{\pi t}{4})[/tex] where p4(t) is a pulse with a duration of 4 seconds and is centered on the origin with a height of 1.
The solution manual says the answer is:
[tex]y(t) = \frac{1}{2}p_{4}(t)sin(\frac{\pi t}{2})[/tex]
Can anyone see where I went wrong or if the solution manual has an error? Thanks!
bump to the top!
10K
