Solving dv/dt = a0√(c² - v²/c²) from t = 0 to infinity
  • Thread starter Thread starter stevmg
    Integral
15 replies · 2K views
stevmg
Sove the differential equation below. Limits, t= 0 to t [itex]\rightarrow \infty[/itex]
a0 is a given value (say, 9.8 m/sec2) at t = 0
dv/dt = a0[itex]\sqrt({c^2 - v^2/c^2})[/itex]
sin-1(v/c) = a0t/c
v/c should go from 0 to 1. My solution does not come up with that.
If your equation is relating physical quantitites, then, by dimensional analysis, you must have:
[tex] [c^{2}] = [\frac{v^{2}}{c^{2}}][/tex]
[tex] [c] = [v]^{1/2}[/tex]
and then (assuming t is time):
[tex] \frac{[v]}{\mathrm{T}} = \frac{\mathrm{L} \, \mathrm{T}^{-2}}{[v]^{1/2}}[/tex]
so
[tex] [v]^{3/2} = \mathrm{L} \, \mathrm{T}^{-1}[/tex]
[tex] [v] = \left(\mathrm{L} \, \mathrm{T}^{-1}\right)^{\frac{2}{3}}[/tex]
and, the dimension of c:
[tex] [c] = \left(\mathrm{L} \, \mathrm{T}^{-1}\right)^{\frac{1}{3}}[/tex]
I don't know of any physical quantity with these dimensions. Can you please explain?
Let's start over again:
dv/[itex]\sqrt({c^2 - v^2})[/itex] = a0dt/c
sin-1 (v/c) = a0t/c
Now, something I have done is wrong... what?
try getting rid of the inverse sine by taking the sine of both sides. everything youve done looks valid so far. what do you mean it doesn't work?
OK -
(v/c) = sin (a0t/c)
t starts at zero and goes to infinity. As it does, v/c starts at zero and ends at c (when t is infinite.) It is supposed to be a monotonic increasing function. The one depicted above by me is not. As t advances, the sine oscillates from -1 ...0 ... +1 ... 0 ... -1 etc.
We have the v/c restricted to -1 ... +1 but this is not considtent with the advancing t's and it is not ever supposed to decrease.
Where did you get this formula:
dv/dt = a0[itex]\sqrt{(1 - v^2/c^2)}[/itex]
Was afraid you would ask that...
That is a formula I concocted to mimick a particle of mass mstarting at ground zero acceleration (9.8 m/sec2) being pushed indefinitely over t forever (t --> infinity.) This takes into account the relativistic momentum with the infamous
m = m0/(sqrt{(1 - v^2/c^2)}[/itex]) equation we learned in high school (used to be called "relativistic mass" but now that term is verboten.
Basicallly it states that at a given instant, a particle which had an initial acceleration (a0) of 9.8 m/sec2 or 1 g now has a reduced acceleration of
a0[itex]\sqrt{(1 - v^2/c^2)}[/itex] depending on the achieved velocity. The dv/dt represents the acceleration at that point in time.
When you integrate or solve the diff eq you do get the restriction of |v/c| [itex]\leq[/itex] |1| which is true but it should NOT be periodic as once a force is applied, there should be no reduction in |v/c|.
Oh, then it's incorrect. You should use a transformation law that relates the acceleration of a particle with respect to a stationary reference frame to the acceleration of the particle with respect to a co-moving inertial reference frame.
You should tak that [itex]a_{0}[/itex] is actually the proper acceleration measured by this co-moving frame, then you will get the correct equation of motion.
So, do you know the acceleration transformation law in relativistic dynamics?
I knew there was something wrong with what I did. No, off the top of my head I do not know this transformation of which you speak. I have Taylor/Wheeler's 1960s book of Spacetime Physics as well as French's book of Special Relativity (1979.)
If you could point the way and maybe supply me with a small simple numeric example that would be most helpful.
This is precisely why I posted this question on this thread.
I am not afraid of hyperbolic functions but straight algebraic ones are more intuitive.
stevmg
Don't leave me now, Dickfore! I need you to finish what you were saying as that will be a learning jump for me...
stevmg
Ok, do you know Calculus? If you do, you can derive everything starting from Lorentz transformations? Do you know them?
Yes, I do know calculus and I do know the Lorentz transformations. It's putting them together that is the problem and that is where my initial error started.
That;s what I need the help in - choosing the right path. If I had known the right path and been able to derive v in terms of t, I wouldn't have been asking the question.
x' = [itex]\gamma[/itex](x - vt)
t' = [itex]\gamma[/itex](t - vx/c2)
where v = the relative velocity of S' to S.
Einstein derived these equations without any supposition that v < c. It was the
[itex]\gamma[/itex] = 1/[itex]\sqrt{(1 - v^2/c^2}[/itex]) which comes along in the development of this proof that put the kibosh on v ever > c.
Ok, now, imagine a particle is at a point with coordinates [itex](x, y, z)[/itex] at some instant [itex]t[/itex] according to the frame S. Since the particle is moving, it will, in general, have different coordinates at an infinitesimally later time [itex]t + dt[/itex]. Due to the finite speed of propagation of the particle, each of the coordinates has to change by an infinitesimal amount. Hence, the coordinates of the particle at a later instant are [itex](x + dx, y + dy, z + dz)[/itex]. By definition, we call the following ratios:
[tex] v_{x} = \frac{dx}{dt}, \; v_{y} = \frac{dy}{dt}, \; v_{x} = \frac{dz}{dt}[/tex]
the components of the velocity of the particle (relative to the frame S).
Using the Lorentz transformation, we may write for the infinitesimal increments of the coordinates and time in the frame S':
[tex] dx' = (x' + dx') - x' = \gamma \, \left[(x + dx) - \beta \, c \, (t + dt) \right] - \gamma \left(x + \beta \, c \, t \right) = \gamma \, \left(dx - \beta \, c \, dt \right)[/tex]
[tex] dy' = (y' + dy') - y' = (y + dy) - y = dy[/tex]
and similarly
[tex] dz' = dz[/tex]
and, finally:
[tex] dt' = (t' + dt') - t' = \gamma \, \left[(t + dt) - \frac{\beta}{c} \, (x + dx) \right] - \gamma \, \left( t + \frac{\beta}{c} \, x \right) = \gamma \, \left(dt - \frac{\beta}{c} \, dx\right)[/tex]
I have written everything out, but notice that what we are doing is expressing the differentials of [itex]x', y', z', t'[/itex] as functions of [itex]x, y, z, t[/itex] according to the rules of Multi-Variate Calculus.
Then, according to S', the components of the velocity are:
[tex] v'_{x} = \frac{dx'}{dt'}, \; v'_{y} = \frac{dy'}{dt'}, \; v'_{z} = \frac{dz'}{dt'}[/tex]
Substituting for all of the above differentials, we get:
[tex] v'_{x} = \frac{dx - \beta \, c \, dt}{dt - \frac{\beta}{c} \, dx}[/tex]
[tex] v'_{y} = \frac{dy}{\gamma \, \left(dt - \frac{\beta}{c} \, dx \right)}[/tex]
and, similarly for [itex]v'_{z}[/itex]:
[tex] v'_{z} = \frac{dz}{\gamma \, \left(dt - \frac{\beta}{c} \, dx \right)}[/tex]
In all of these equations [itex]\beta = \frac{u}{c}[/itex], where [itex]u[/itex] is the relative velocity of the frame S' with respect to S and [itex]\gamma = (1 - \beta^{2})^{-1/2}[/itex].
If you divide each term in both the numerator and the denominator by [itex]dt[/itex] and use the definitions for the components of the velocity in the frame S, then you will get:
[tex] v'_{x} = \frac{v_{x} - u}{1 - \frac{v_{x} \, u}{c^{2}}}[/tex]
[tex] v'_{y} = \frac{v_{y} \sqrt{1 - \frac{u^{2}}{c^{2}}}}{1 - \frac{v_{x} \, u}{c^{2}}}[/tex]
[tex] v'_{z} = \frac{v_{z} \sqrt{1 - \frac{u^{2}}{c^{2}}}}{1 - \frac{v_{x} \, u}{c^{2}}}[/tex]
These are the transformation formulas for the components of the velocity. Notice that the formula for the z-component is the same as for the y-component by making the substitution [itex]y \rightarrow z[/itex] everywhere. You can get the inverse transformations (from S' to S) in two ways. Either solve the above equations for the unprimed velocity components or simply use the same formulas with the place of the unprimed and primed components interchanged and [itex]u \rightarrow -u[/itex]. You should get the same result.
Now comes your question:
1. Find the differential [itex]dv'_{x}[/itex] (assuming [itex]u[/itex] is constant);
2. Find the differentials [itex]dv'_{y}[/itex] and then [itex]dv'_{z}[/itex] by analogy;
3. Use the definition of acceleration in S' and S and the above expression for [itex]dt'[/itex] to find the acceleration components transformation formulas.
Ill restrict to ONE dimension (say the x dimension) and work on that. Right now I have to watch Becker - my role model.
and similarly
and, finally:
After I differentiate 1) [I don't need to worry about 2) and 3)] - I know
denominator times the derivative of the numerator minus the numerator times the derivative of the denominator all over the denominator squared - how painful does it get?
What will I have? Where does it get me?
Remember my question was take a mass m0 and push it with force f. With m0 at rest the initial acceleration will be a0. As m0 moves (gets a velocity v) its acceleration will decrease as v increases. They used to call it "relativistic mass" but that is a forbidden term.
The old equation used to be: m = m0/[itex]\sqrt{(1 - v^2/c^2)}[/itex]
Its acceleration at time t will be: a0[itex]\sqrt{(1 - v^2/c^2)}[/itex]
This, we have the differential equation:
a = dv/dt = a0[itex]\sqrt{(1 - v^2/c^2)}[/itex]
That is where I got the brainy idea to solve that diff eq to get the v after a force f, which gave an initial acceleration of a0 when the object was at rest, was applied for time t. But then the solution with the arcsin answer gave a periodic function which didn't make any sense at all. One intuitively knows that even though the acceleration is getting smaller the faster the object is moving that it is still accelerating and has a limit of c if t is infinite.
yuiop said:
Let us say the traveling twins accelerates for time [tex]\tau_{a1}[/tex] as measured by his own clock and with constant acceleration (a1).
He can then calculate that the time that elapsed (Ta1) in the Earth frame during the acceleration phase is:
[tex]T_{a1} =\frac{c}{a_1}\, sinh(a_{a1} t_{a1}/c)[/tex]
and that his terminal velocity (v) after the acceleration phase is:
[tex]v = \frac{a_1 T_{a1}}{\sqrt{1+(a_1 T_{a1}/c)^2}}[/tex]
He now cruises for time [tex]\tau_{c}[/tex] as measured by his own clock and can calculate the time elapsed Tc on the Earth clock as
[tex]T_c = \frac{\tau_c}{\sqrt{1-v^2/c^2}}[/tex]
He now decelerates with constant acceleration -a2. He can calculate the time [tex]\tau_{a2}[/tex] (as measured by his own clock) it will take to come to rest with respect to the Earth as:
[tex]t_{a2}=\frac{c}{a_2}\, artanh(v/c)[/tex]
The above equation is valid even if the rocket does not actually stop but continues reversing direction.
The time that elapses on the Earth clock during the deceleration phase is:
[tex]T_{a2} = \frac{c}{a_2}\, sinh(a_2 \tau_{a2}/c)[/tex]
None of the above calculations require contact with the Earth after take off. All that is required is an onboard accelerometer, a clock and a calculator for the rocket captain to know when he has come to rest with respect to the Earth and how much time has elapsed on the Earth relative to his own clock in the Earth rest frame.
The final solution as posted by yuiop. I don't know how he got it but that is the answer.
