Solving Final Temp of Ice & Water Mixture
The final temperature of a mixture consisting of 100g of ice at 0.0°C and 500g of water at 100°C is calculated using the principles of heat transfer and phase change. The relevant equations include Q=mL for latent heat and Q=mcΔt for specific heat. After correcting initial miscalculations, the final temperature is determined to be approximately 70.07°C. This result aligns with the expectation that the larger mass of water significantly influences the final temperature.
  • Understanding of thermodynamics principles, specifically heat transfer.
  • Familiarity with specific heat capacities of water and ice.
  • Knowledge of latent heat concepts, including heat of fusion and vaporization.
  • Ability to manipulate algebraic equations to solve for unknowns.
  • Review the concept of heat transfer in phase changes, focusing on latent heat calculations.
  • Explore the specific heat capacities of various substances to understand their thermal properties.
  • Practice solving similar problems involving mixtures of different states of matter.
  • Learn about the implications of mass and temperature differences in thermal equilibrium scenarios.
Students studying thermodynamics, physics educators, and anyone interested in understanding heat transfer in mixtures of different states of matter.
Arooj
A 100g piece of ice at 0.0°C is dropped into 500g of water at 100°C. What is the final temperature of mixture.
Q=mL (latent heat)
Q=mcΔt
Qw=-Qx (energy absorbed by water is equal but opposite to that of substance inserted into water)
specific heat ice: 2.09 * 10^3 J/kg * °C
specific heat water: 4.186 * 10^3 J/kg * °C
specific heat steam: 2.01 * 10^3 J/kg * °C
latent heat of fusion: 3.33 * 10^5 J/kg
latent heat of vaporization: 2.26 * 10^6 J/kg
Do you find the total heat including phase change heat for both substances, using final temperature as an unknown variable? If so:
Q = mcΔt + mL
Qw = (0.5 *4.186 * 10^3 *(Tf-100)) + 0.5 * 2.26 * 10^6
Qx= -((0.5 *4.186 * 10^3 *(Tf-0)) + (0.5 * 3.33 * 10^5))
I set both equal after simplifying, and obtained a final temperature of 264.14°C, which is too bizarre of an answer.
The water at 100C is still liquid, so the heat of vaporization is not needed.
However, the ice at 0C is solid, and the heat of fusion must be added to the ice to melt it.
Only the piece of ice undergoes a phase change. The hot water remains water as it cools to the final temperature. So, think about how you wrote Qw. Also, I think you used the wrong mass for the ice in your expression for Qx.
Thanks for the help. Not including the heat of vaporization, I got 28.08 C. I also did have a mistake in calculating the energy of the piece of ice where I put it the mass of the water instead. Is 28.08 a reasonable answer, or should it be closer to 100 C because the more massive object would have more of an influence on the temperature?
I get the final temperature to be quite a bit higher, in agreement with your intuition.
To get 28.08 I did
Qw=-Qx
(0.5 *4.186 * 10^3 *(Tf-100)) = -((0.1 *4.186 * 10^3 *(Tf-0)) + (0.1 * 3.33 * 10^5))
2093Tf - 209300 = -418.6Tf - 33300
2511.6Tf = 176000
Tf = 70.07 C
I think I have it, I might have made some original mistake in calculation.
That looks good.
As a rough approximation, ice at 0°C corresponds to (hypothetical) water at -80°C. So you heat 100g by 150° and cool five times this amount by 1/5 of the temperature difference. The .07 are the deviation from this approximation ;).
  • · Replies 17 ·
