Solving for 'b': Current in a Loop w/ Bsin(1000t+b)
  • Thread starter CoolDude420
    Current Loop
CoolDude420
steady-state current through the loop will be of the form Bsin(1000t +b). What is the phase angle 'b'? in rads
Handwritten phasor-domain circuit working: a series loop with a 6 V source, 4 ohm resistor, inductor 1/(2j) and capacitor 1/(0.25j), with I = ? and the voltage across the 4 ohm resistor written as 4/(4 + 1/(2j) + 1/(0.25j)) times 6, giving 24 over the sum.
Handwritten working on lined paper deriving a phasor current I = V/R, with complex-number steps, r = sqrt(a^2 + b^2) = 0.66, and theta = cos^-1(a/r) = 9.65 x 10^-5 with question marks, followed by a crossed-out scribbled section.
[/B]
The answer is meant to be 0.46rads/s. However I am getting 9.65x10^-5??
I have no idea what I did wrong.
I first converted everything into the phasor domain. Then I used voltage division to get the voltage drop across the resistor. Then I used Ohms Law to get the current through the resistor which is the same as the current through the circuit.
Check your calculation for the impedance of the inductor. The formula for the impedance of an inductor is not he same as that of a capacitor.
Don't be afraid to promote j's in the denominator to the numerator. If you have a value like ##1/0.25j##, then this can become ##-4j##.
You don't need to do any voltage division here. Simply sum up the impedances to find the total impedance. Then apply Ohm's law directly: ##I = E/Z## (where E is the applied potential difference across Z).
Ah.
Finally got it. Thank you soo much.
It says in my lecture notes that inductors can be described be V = jwLI or I = 1/jwL * V
It says nothing else. How do I know like what to use when? I mean say I am converting a 2H inductance into the phasor form, how do I know what to use?
