Solving for interest rate r in compound interest equations
  • Thread starter Thread starter Grits
13 replies · 3K views
Grits
I am new to the site but I need some math help. I am a business major and I am taking Business Finance. He wants us to do a bonus quiz to see how well our math skills are for the class. Well I can't seem to figure them out.
Someone please help.
(1 + r)^2 = 10
(1+r)^2=10
(1+r)(1+r)=10
1+1r+1r+r^2
1+2r+r^2=10
2r+r^2=9
r^2=9-2x/x
r=9-2 =7?
60= [400/ (1 + r)^3]
If PV=110 r=.09 and t=4 find fv when fv= pv*(1+r)^t.
Solve for r directly when FVt=PVo *(1+r)^t
Up to this point, namely [tex]2r+r^2=9,[/tex] your work is ok, but the next line isn't right. There is, however, a more direct solution:
[tex](1+r)^2=10[/tex]
[tex]\sqrt{(1+r)^2}=\sqrt{10}[/tex]
[tex]1+r=\pm\sqrt{10}[/tex]
[tex]r=-1\pm\sqrt{10}[/tex]
[tex]60= \frac{400}{(1 + r)^3}[/tex] assume that [tex]r\neq -1[/tex] to get [tex](1 + r)^3= \frac{400}{60}=\frac{20}{3}[/tex]
and then take the cube root of both sides to get... you try.
so does r = 295
(20/3)^3 = 296
r=296-1
Grits said:
so does r = 295
(20/3)^3 = 296
r=296-1
Cube root, one third power. You're cubing it when you should be taking the cube root.
Cyclovenom said:
Use
[tex]r = \sqrt[3]{\frac{20}{3}} -1[/tex]
how do i put that in my calculator
This is just substitution. [tex]fv=(110)(1+.09)^4[/tex]
Remember to use the order of operations.
Edit: Type this in you calculator: [tex](\frac{20}{3})^{\frac{1}{3}}[/tex], then subtract one from that answer.
2nd Edit: I'm using LaTeX for the first time, and I was wondering if/how you can make the parentheses larger. That looks weird. Could someone please clean that up and make it look better so I can look at the proper code :)?
Grits said:
Here's another
Solve for r directly when FVt =PVo *(1+r)^t
Well what comes first to your mind?
Start by isolationg the (1+r)^t term.
If r=8%, t=5 and m=4 find the timve value factors given below:
FVIF r%/m,t*m=[(1+(r/m))^t*m]
I got 1 as the answer I just canceled out and got 1 left over.
Well actually is basic algebra.
For example:
[tex]a = \frac{bc}{d \sqrt{e}}[/tex]
Now if you want to isolate let's say e what must you do?
first off you could multiply both sides of the equation by [itex]\sqrt{e}[/itex]
[tex]\sqrt{e} a = \frac{ \sqrt{e} bc}{d \sqrt{e}}[/tex]
Now you can see you have
[tex]\sqrt{e} a = \frac{bc}{d} \frac{\sqrt{e}}{\sqrt{e}}[/tex]
Thus
[tex]\sqrt{e} a = \frac{bc}{d}[/tex]
Now you should divide both members by a
[tex]\sqrt{e} \frac{a}{a} = \frac{bc}{da}[/tex]
thus
[tex]\sqrt{e} = \frac{bc}{da}[/tex]
Now using the fact that [itex]\sqrt[n]{e} = e^{\frac{1}{n}}[/itex]
[tex]e^{\frac{1}{2}} = \frac{bc}{da}[/tex]
So if we square both sides
[tex](e^{\frac{1}{2}})^2 = (\frac{bc}{da})^2[/tex]
Using the fact that [itex](e^n)^m = e^{nm}[/itex]
[tex]e^{\frac{2}{2}} = (\frac{bc}{da})^2[/tex]
[tex]e = (\frac{bc}{da})^2[/tex]
We succesfully isolated e.
Now try it with your equation.
