Solving for Mass in a Spring Scale Experiment
bodensee9
Hello:
If a person rides on a wheel that has the same speed throughout rotation. Does this mean that magnitude of angular velocity is same throughout rotation? I think if the wheel has the same speed, then the centripetal force is equivalent throughout rotation.
Now, the person decides to carry a spring to weigh himself. The maximum of the spring reads X, and the minimum reads Y.
So, wouldn't I have:
w = angular velocity
N = normal
R = radius of wheel
-N - mg = -mw^2*R (at top)
N - mg = mw^2*R (at bottom)
So, N top = mw^2*R - mg, N bottom = mw^2*R + mg? And N top = Y, and N bottom = X. I am supposed to find m, but somehow there's something wrong with this equation. Thanks.
Yes it is. I think mv^2/R would be the same both top and bottom because your speed is the same, no? Thanks.
If the wheel is rotating at the same speed, then yes, that is a question that answers itself from what you've given.
If your problem is to find an expression for m ...
Then you also need to consider that F = k*x such that
kΔX = ΔF = mg + m*ω2r - (mg - m*ω2r)
Then express as m?
Hello:
I'm sorry, but what is F= kx? I thought that was the force that causes a displacement of a spring? Thanks.
bodensee9 said:
Hello:
It is. The displacement of the spring at the bottom is X, at the top it is Y. The Δdisplacement of the spring reading they give you then is (X - Y). And this means the ΔForce is the Force at the Bottom minus the Force it reads at the Top.
You can write then
ΔF = kΔX = mg + m*ω2r - (mg - m*ω2r) = 2*m*ω2r = k*(X - Y)
You can rearrange for m.
