Solving for Two Identical Violin Strings
  • Thread starter Thread starter stylez03
    Strings Violin
28 replies · 8K views
stylez03
Two identical violin strings, when in tune and stretched with the same tension, have a fundamental frequency of 440 Hz. One of the strings is retuned by adjusting its tension. When this is done, 2 beats per second are heard when both strings are plucked simultaneously.
a. What is the highest possible fundamental frequency of the retuned string?
b. What is the lowest possible fundamental frequency of the retuned string?
c. By what fractional amount was the string tension changed if it was increased?
F_beat = T_b - T_a / Ta*Tb => 1/Ta - 1/Tb
F_beat = f_a - f_b
I'm only given 2 values and I'm not sure where to go with this problem
for a and b--you know that if two pitches are sounded two hertz apart, two beats per second will be heard (your formula). you can figure this out prett easily from there (there are only two possibilities--one high and one low.
If they both have a frequency of 440hz, and it's 2 beats per second and the beat frequency is just the difference between them, is it just 442 and 440 ?
442 is the correct answer for a). What about b) and c) ?
b) 438
c) I'm not sure how to start it.
What is the relationship between the tension in a string and the velocity of propagation of a traveling wave in the string? And what is the relationship between the propagation velocity of a traveling wave in a string, versus the fundamental oscillation frequency of a string that is fixed at both ends and plucked?
For the 1st relationship v = sqrt(Force of Tension / Mass Density)
For the 2nd relationship fundamental oscillation frequency is Fn = nv / 2L
F_1 = nv / 2L
442 = 1*v / 2L
442 = 1 * (F_t / Mass Density) / 2L
Though the given's don't provide the mass density of the string or the length of the string. This is where I'm a little confused on.
The mass density and the length do not change. So when you calculate the percent change in the tension based on the percent change in the frequency, those other variables should cancel out. Oh, they asked for the "fractional" change, so maybe I should have said fractional instead of percent. Same concept, though.
So the fractional change would be
fn = n *Force of tension / 2
f1 = 1 * Force of tension / 2
f1 = 442
442 = 1*Force of Tension / 2
? If this is right so far, what is the original force of tension, I know it gives the original frequency at 440hz at the same force of tension.
This is what you should use. The frequency ratios directly with the velocity of propagation. And the velocity ratios with the sqrt of the tension. So if the frequency goes up to 442 Hz from 440 Hz (fractional amount 2/440), what does that say about the fractional change of the tension required to make that change?
So basically the fractional increase is 2/240 and the fractional decrease is 2/338 ? Thank for taking the time to explain this, it's been a few years since I've taken physics, jumping back into finish the final course.
Hold on... Those are the fractional changes of the frequency. You are asked in c) to find the corresponding fractional change in the tension to cause the positive fractional frequency change. The tesion change is not 2/440.
Okay so the fractional amount from 442hz to 440hz is 2/440. Now the question ask for the fractional change in tension. The thing I'm confused about is finding out the tension force. You said that the Mass Density and the Lenght is constant so they should cancel out.
From that
F = 1 * Force of Tension / 2
I guess I'm still not following on what is the current Force of Tension.
From that
Okay, I'm just trying to get you to see how you involve the square root thing.
Take this analogy to see if it helps. The length of the side of a square is equal to the sqrt(Area), right? Now, if I increase the length of a side of a square by 2/440, what is the fractional change in the Area?
Fractional change in Area would be Sqrt(2/440) ?
In the square Area analogy:
[tex]\frac{\Delta L}{L} = \sqrt{\frac{\Delta A}{A}}[/tex]
What mathematical operation do you perform on both sides in order to isolate the answer that is desired?
[tex]\frac{\Delta A}{A} = ??[/tex]
You have to square both sides.
EDIT:
Would the fractional change in tension be the sqrt(442/440)?
Woo-hoo! So what is (2/440)^2?
Note how the tension goes up, but not as much as the frequency goes up (since the fractional change in frequency is less than one).
(2 / 440)^2 = 2.0661157 × 10-5Is is (2/440)^2 or (2/442)^2 for the increase?
It's the change over the original. You started at 440 Hz, right?
EDIT:
I'm entering this equation into the online submission program and it's saying that it's incorrect for:
(2/440)^2
stylez03 said:
EDIT:
(2/440)^2
Hmmm. Maybe I misinterpreted what they meant by fractional increase. Like, you can say there was an increase of 1/2 if something increases by 50%, or you can say that the total in the end was 150%.
I wonder if they mean for the "fractional increase" to be (442/440)^2 ? Can you try that to see if that matches the answer?
I've tried that, that also fails.
Sorry, I don't know what I'm missing or misinterpreting.
With a base frequency of 440 Hz and and offset of 2 Hz, I don't see many alternatives. I think we did the math correctly. I'll try pinging a few other Mentors/homework helpers to see if they can see an error, but otherwise, I guess we need to wait to hear your prof's explanation.
There's a small mistake here...
We have established so far that [itex]f'/f = \sqrt{T'/T}[/itex], or [itex]T'/T = (f'/f)^2[/itex].
So, next, we simply plug in f'=442Hz and f=440 Hz for the 2 fundamental frequencies and find the square of the ratio and this tells us T'/T. Subtract 1 from this (since [itex]\Delta T/T = (T'-T)/T = T'/T - 1[/itex]) and you're through.
Read on, if you want to know what went wrong above...
The error is in making the jump from [itex]T'/T = f'^2/f^2[/itex] to [itex]\Delta T/T = (\Delta f)^2/f^2[/itex]. This is not true, since [itex]\Delta T/T = T'/T - 1 = (f'/f)^2 - 1 = (f+ \Delta f)^2/f^2 - 1 = ((\Delta f)^2 + 2f \Delta f)/f^2 \neq (\Delta f)^2 /f^2[/itex]
In fact, since [itex]\Delta f << f~,~~~ \Delta T/T \approx 2\Delta f/f[/itex]
