Solving for y in a logarithmic equation involving |y|
  • Thread starter Thread starter schniefen
    Logarithmic
12 replies · 2K views
schniefen
Solve for ##y## in the below equation and find the value of the constant of integration.
Find the equation of the curve ##y'(x)\frac{1}{y}=\frac{1}{2x^3}## in terms of ##y=y(x)## if it passes through the point ##(1,1)##.
Integrating both sides of the equation yields
##\ln{|y|}=-\frac{1}{4x^2}+C ##
##\iff \ln{|y|}=-\frac{1}{4x^2}+\ln{D} ##
##\iff |y|=De^{-\frac{1}{4x^2}}##
At ##(1,1)##, ##D=e^{\frac{1}{4}}##. So for ##y>0##, ##y=e^{ \frac{1}{4}-\frac{1}{4x^2}}##, and for ##y<0##, ##y=-e^{\frac{1}{4}-\frac{1}{4x^2}}##.
Apparently one can solve for ##y## so that ##y=e^{ \frac{1}{4}-\frac{1}{4x^2}}## for all ##y##. How?
I don't see how you go from the 2nd line to the 3rd. Why are you grouping as a product. That holds when you use ln, but you're going in the opposite direction, taking exponentials: ##e^{a+b} \neq e^a+e^b ##
## \ln{|y|}=-\frac{1}{4x^2}+\ln{D}##
##\iff \ln{|y|}-\ln{D}=-\frac{1}{4x^2}##
##\iff \ln{\frac{|y|}{D}}=-\frac{1}{4x^2}##
##\iff \frac{|y|}{D}=e^{-\frac{1}{4x^2}}##
Is this incorrect?
Is this incorrect?
Looks fine. Now use the condition that the solution passes through (1,1) to find D and sub in the last equation.
At ##(1,1)##, ##D=e^{\frac{1}{4}}##, so ##|y|=e^{\frac{1}{4}-\frac{1}{4x^2}}##. How can one conclude from here that ##y=e^{\frac{1}{4}-\frac{1}{4x^2}}##?
Notice that ##e^x>0 ## for all x.
$$\int \frac {dy}{y}= \int \frac{1}{2}x^{-3}dx $$​
$$ log(y) = -\frac {1}{x^2} + C $$​
$$y= exp(-\frac{1} {x^2} + C) $$​
$$ log(1) = -1 +C $$​
$$0=C-1 $$​
$$C=1$$​
$$0=C-1 $$​
$$C=1$$​
Sorry, I don't see your point. How does this relate to the OP?
yes, but that says nothing about ##y## doesn't it? of course it'll be positive since ##|y|## is.
But we know |y|=y and that is all we need, isn't it?
This is a first order linear differential equation, the solution is ##y=a\exp{(\int\frac{1}{2x^3}dx)}##.
But the response given also checks out.Edit: The given expression may be equivalent to yours.
You have a mistake in the line above. Check your integration.
$$0=C-1 $$​
$$C=1$$​
