Solving Harmonic Oscillator Equation w/ Initial Conditions
9 replies · 2K views
quas
a mass is placed on a loose spring and connected to the ceiling. the spring is connected to the floor in t=0 the wire is cut
a. find the equation of the motion
b. solve the equation under the initial conditions due to the question
## \sum F=ma
## x(t)=Asin(\omega t + \phi ) ##
a. due to the 2 law of Newton: ## \sum F=ma_x
## mg-kx=ma ##
mg-kx=m\ddot{x}
\ddot{x}=g-\frac{k}{m}x ##
b. first I'll find the point equilibrium
c-kx=ma
c-kx=m\cdot 0
x_0=\frac{c}{k}
then I'll define ## y=x-x_0 ##
How do I go from here?
thanks
quas said:
##\ddot{x}=g-\frac{k}{m}x ##
OK
##x_0=\frac{c}{k}##
What does c stand for?
Rewrite the differential equation in terms of y instead of x.
As TSny hints, you tripped finding x0. Think again what condition will be true at equilibrium and define x0 again. There won't be an unknown c.
TSny said:
OK
What does c stand for?Rewrite the differential equation in terms of y instead of x.
sorry I meant ## x_0 = \frac{mg}{k}##
ok and then ## \ddot{y}=g-\frac{k}{m}y ## ?
\ddot{y}=g-\frac{k}{m}y## can't be right. Compare with ##
\ddot{x}=g-\frac{k}{m}x##
I might have a barrier but I do not understand how to build a differential equation for y,,,,
I understand that ## \dot{x}=\frac{dx}{dt}=\frac{dy}{dt}=\dot{y} \\ a=\ddot{x}=\frac{d^2x}{dt^2}=\frac{d^2y}{dt^2}=\ddot{y} ##
? I must be thick this morning, but if positive y is down that looks ok to me.
Oh, good grief. It took me a minute!
Much later after it stops oscillating and y is y0 what is the acceleration? g?
Simple: the second derivatives on the left are equal alright. But you need to substitute your expression for y in terms of x. Not just y = x, but: ...:rolleyes:
