Solving Inequality: |x-1|+|x-2|>1
  • Thread starter solar nebula
4 replies · 2K views · last reply
solar nebula
So this is the question
|x-1|+|x-2|>1
N/A
I tried it, the solution seems right, but i don't know if my approach is correct.
Handwritten-style worked solution to |x-1| + |x-2| > 1 split into two cases: case 1 gives 2x - 3 > 1 so x > 2; case 2 gives -2x + 3 > 1 so x < 1; a number line marks 1 and 2 with arrows pointing left from 1 and right from 2.
Think about these absolute values like this:
At x=1 or x=2, one of the absolute values is 0, so you can call these the "roots" (thought not technically roots, I can't think of a more appropriate name for them right now), so what you want to do is check all possibilities around those roots, and the roots themselves.
Check:
x<1
For this range, both [itex]x-1[/itex] and [itex]x-2[/itex] will be negative, so the inequality you need to solve would be [tex]-(x-1)-(x-2)>1[/tex]
1<x<2
Here you will have [itex]x-1>0[/itex] and [itex]x-2<0[/itex] so what you need to solve is [tex](x-1)-(x-2)>1[/tex]
x>2
For this value, both are positive so it should be clear what you need to solve here.
And then always check the "roots" themselves. Plug in the values of x=1 and x=2. By this point, you've checked all possible cases and should have your solution set.
The way I learned it:
To solve |ax+b|>k, solve ax+b>k and ax+b<-k. (This is basically what you did.)
Then I would plug test values into the original equation to see if it makes a true or false statement. You would use the intervals (-[itex]\infty[/itex],1);(1,2);(2,[itex]\infty[/itex]).
The values from those intervals that make true statements give you your solution set.
edit: I just realized that your question is a special case. What if it was instead [tex]|x-1|+|x-2|>2[/tex] or [tex]|x-1|+|x-2|>0[/tex] ? For the first what you need to do is check when [tex]|x-1|+|x-2|=2[/tex] and then check each interval around that.
