Solving Initial-value Problem: Different "C" Values Explained
5 replies · 2K views
Astro
Wondering why getting different values of "C" depending on how I solve the question. Not sure the values are different. Thanks.
1. Homework Statement
Solve the initial value problem [itex]cos(x)Ln(y) \frac{dy} {dx} =ysin(x)[/itex], y>0, y(0)=e2.
N/A.
[itex]∫ \frac{Ln(y)} {y} dy=∫ \frac{sin x} {cos x} dx[/itex]
u=Ln(y)
[itex]du=\frac{1} {y}[/itex] dy
dy=y du​
[itex]∫ \frac{u} {y} y du=∫ tan(x) dx[/itex]
## \frac{1} {2}u^2+C_1=Ln|sec(x)| + C_2 ##
##\frac{1} {2}Ln^2 (y)=Ln|sec(x)| + C_3 ## ,Since ## C=C_2-C_1 ##
## Ln(y)=± \sqrt{2 Ln|sec(x)|+C} ## Equation #1
## y=e^{± √(2Ln|sec(x)|+C)} ##
## e^2=e^{+√(2Ln|sec(x)|+C)} ## Since y(0)=e2. Also, exponent cannot be -ve since LS.=RS.
## e^2=e^{+√(2(0)+C)} ##
##2=√C ##
## C=4 ##
Therefore ## y=e^{± √(2Ln|sec(x)|+4)} ## <--- ANS #1
However, if we try solving for C using eqn #1:
## \frac{1}{2}Ln^2(y)=Ln|sec(x)|+C ##
## \frac{1}{2}Ln^2(e^2)=Ln|sec(0)|+C ##
## \frac{1}{2}(2^2)Ln^2(e)=Ln(1)+C ##
## 2(1)=0+C ##
Therefore, ## y=e^{± √(2Ln|sec(x)|+2)} ## <----ANS #2.
However, obviously ANS #1 ≠ ANS #2. Can someone please help me understand why and what I did wrong?
Thanks.
N/A.
u=Ln(y)
dy=y du​
##2=√C ##
## C=4 ##
## 2(1)=0+C ##
Thanks.
You don't use eqn #1 in the second part, but the equation immediately above it:
Notice that ##C_3## is not equal to your final ##C##.
The two "C" here differ by a factor of 2.
Approach 1 is correct, approach 2 gives you C3 = 1/2 C = 2 which leads to C=4 as well.
I'm not sure I follow.
To solve for the correct answer for "C" (which is C=4 according to the textbook), all I did was rearrange ## \frac{1}{2}Ln^2(y)=Ln|sec(x)|+C ## to solve for "y" and then subbing in the initial values x=0, and y=e^2 gives you ## e^2=e^{\sqrt{C}} ## from which you get C=4. But, when I sub in the initial values directly into ## \frac{1}{2}Ln^2(y)=Ln|sec(x)|+C ## and rearrange for C I get a different answer. It's unclear to me why I'm getting different answers because in both cases the variable C is the same. Solving for C two different ways when you're only rearranging the equation differently to find C should give you the same answer if you apply the rules of logarithms and exponents correctly. The fact that I'm not getting the same value of C means that I'm not understanding some basic concept of math or that I'm making a mistake when I'm rearranging and solving for C.
You forgot to multiply C2-C1 by 2.
(bolding mine)
What I bolded is wrong.
When you solve for ##C## using ## y=e^{± √(2Ln|sec(x)|+C)} ##, you find ##C=4##. That is correct.
When you solve for ##C_3## using ##\frac{1} {2}Ln^2 (y)=Ln|sec(x)| + C_3 ##, you find ##C_3=2##. That is correct too.
But, as mfb, ehild and myself have mentionned, the constants in these two equations are not equal. You confused yourself by renaming ##C_3## to ##C## when you tried to find the constant using ##\frac{1} {2}Ln^2 (y)=Ln|sec(x)| + C_3 ##.
Let's rewrite you equations keeping ##C_3##:
## Ln(y)=± \sqrt{2 Ln|sec(x)|+2C_3} ##
## y=e^{± √(2Ln|sec(x)|+2C_3)} ##.
You see? Your final ##C=2C_3##, that's why you find 4 using one equation, and 2 using the other.
