Solving linear inhomogeneous recurrence with 3^n term
32 replies · 8K views · last reply
stanyeo1984
How do I solve this
1. (a) Solve the recurrence relation
an =6an−2 +8an−3 +3an−4 +64·3^n−4, n􏰀>=4
where a0 =0,a1 =1,a2 =4 and a3 =33.
(b) Write down a closed form of the generating function of the sequence an.
Hello, stanyeo1984! :D
I have given your thread a title briefly describing the problem. A title like "Discrete Math" posts in the "Discrete Mathematics, Set Theory, and Logic" forum adds no further information. This was, our members can see the nature of the problem at a glance when viewing the thread listing.
What does the following mean:
n􏰀>=4 ?
For part a) can you identify:
i) The characteristic roots.
ii) The form of the particular solution?
n􏰀>=4 ?
hello, n>=4 just means greater than or equal to 4,
I think i got the characteristic roots as (x-3)(x+1)3
But I got stuck after that
Yes, I understand n >= 4, I just had trouble with n􏰀>=4.
Yes, the characteristic equation is:
$$r^3-6r^2 -8r-3=(r-3)(r+1)^3=0$$
So, you have the root $r=3$ and the root $r=-1$ of multiplicity 3...what's the general form of the homogeneous solution then?
Is the general form C13n+C2(-1)n+C2(-1)n+C2(-1)n
Otherwise, I don't know how to deduce the general solution:/
No, we require each term to be linearly independent of one another, and so the homogeneous solution would be:
$$h_n=c_1(3)^n+c_2(-1)^n+c_3n(-1)^n+c_4n^2(-1)^n$$
Now, bearing in mind all of the terms of the homogeneous solution, what must the form for the particular solution $p_n$ be?
MarkFL said:
No, repeated roots require each term to be linearly independent of one another, and so the homogeneous solution would be:
I'm thinking that the particular solution pn would be 64.C53n-4
No, that's a constant time $3^n$, which we already have as a term in the homogenous solution...so we need to add a factor as we did to two of the terms in the homogeneous solution because we had a repeated characteristic root. We don't need to use the constant $64\cdot3^{-4}$ in the particular solution...so I would state:
$$p_n=An3^n$$
Now, can you use the method of undetermined coefficients to find $A$?
$$p_n=An3^n$$
I'm only familiar for the method of undetermined coefficients for DE not so much for this, is it possible for you to explain?
It's very similar, except that there is no differentiation involved which actually makes it simpler. I would begin by arranging the difference equation as follows:
$$a_{n}-6a_{n−2}-8a_{n−3}-3a_{n−4}=64\cdot3^{n-4}$$
Now, it we assume that $a_n=An3^n$, then by substitution, we obtain:
$$An3^n-6A(n-2)3^{n-2}-8A(n-3)3^{n-3}-3A(n-4)3^{n-4}=64\cdot3^{n-4}$$
Next, let's multiply through by $$3^{4-n}\ne0$$ to get:
$$An3^4-6A(n-2)3^{2}-8A(n-3)3-3A(n-4)=64$$
Now, distribute, combine like terms and solve for $A$...what do you find?
I solve for A=1/3 and therefore, pn= 1/3n3n
Good! :D
So, using the principle of superposition, what is the general solution? And from here we can use the given initial values to determine the parameters $c_i$.
And now I add that to the end of the characteristic solution and solve for C1 and the other constants?
Yes, by the principle of superposition, we know:
$$a_n=h_n+p_n=c_13^n+c_2(-1)^n+c_3n(-1)^n+c_4n^2(-1)^n+\frac{1}{3}n3^n$$
We have 4 parameters to determine, and fortunately we were given the 4 initial values:
$$a_{0}=0,\,a_{1}=1,\,a_{2}=4,\,a_{3}=33$$
So, what we will get is a 4X4 system of linear equations we must solve. Can you set up the system?
From here we get, C1=0, C2=0, C3=1 and C4=1
I get:
$$\left(c_1,c_2,c_3,c_4\right)=(0,0,1,-1)$$
MarkFL said:
I get:
Sorry yes, missed the - sign, but if i place these in the place of the variable in the general solution, won't i get a closed formula?
And if that's correct, what do I do when the question asks me to solve?
This means the closed form satisfying all of the given conditions is:
$$a_n=n(-1)^n-n^2(-1)^n+\frac{1}{3}n3^n=n\left((-1)^n\left(1-n\right)+3^{n-1}\right)$$
Managed to work that one out:D, but what do they mean when they ask me to solve the recurrence relation?
Solving a recurrence relation (or difference equation) is what we just did. :D
Oh, so finding the constants and placing them back in the general equation constitutes as solving the equation?
- - - Updated - - -
Or does question b ask for something else?
It is the entire process:
  • Find the characteristic roots, and from those determine $h_n$
  • Determine the form of $p_n$ and use the method of undetermined coefficients to get $p_n$
  • Use the principle of superposition to state the general solution $y_n=h_n+p_n$
  • Use the initial values with the general solution $y_n$ to determine the parameters
Part b) asks for the generating function, which is related to the closed form, but I have to run now to work on a coding project. Post what progress you have made with the generating function, and perhaps someone else can help with that. :D
hmm. So would you guys please give clear answer of the part a?
also is "an=n(−1)n−n2(−1)n+13n3n=n((−1)n(1−n)+3n−1)" the answer of the part b?
For part a), I wrote:
$$a_n=n\left((-1)^n\left(1-n\right)+3^{n-1}\right)$$
As far as part b), I would invite anyone with a better understand of generating functions to provide help. It's been so long for me that I would have to do research as a refresher, and I simply don't have time. :D
I really appreciate you for part a.
$$a_n=n(-1)^n-n^2(-1)^n+\frac{1}{3}n3^n=n\left((-1)^n\left(1-n\right)+3^{n-1}\right)$$[/QUOTE]
isn't it the answer of part b?
I really thankful with your prompt reply :)
Discrete Math(recurrence relations)
1. (a) Solve the recurrence relation $$a_{n}=6a_{n−2}+8a_{n−3}+3a_{n−4}+64\cdot3^{n-4}$$
please some one note that the clear answers of (a) and (b)!
All arguments and working must be shown
it is pretty tough...!
This question has already been posted...and you have even posted in that thread so I know you are aware of its existence...why are you re-posting it? (Wondering)
edit: I went ahead and merged the newer duplicate with the older thread. Please note that part a) has already been answered, and be patient and wait for someone to post help with part b), OR post what progress you have made with it.
scott1204 said:
any one can get a closed form of the generating function of the sequence $$a_n$$
Is this a question/request or a statement? If the former, have you tried doing it yourself as per rule #11 http://mathhelpboards.com/rules/?
I tried to solve over 4hrs but I couldn't get it...
I also tried to find how to make generating function through the online, it does not work...
