Show that I + N is invertible using the 1/(1+x) Maclaurin series
  • Thread starter Thread starter angelz429
    Matrices
11 replies · 4K views
angelz429
[SOLVED] Nilpotent matrices
Use the McLaurin series for 1/(1+x) to show that I + N is invertible where N is a nilpotent matrix.
n/a
It has something to do with the inverse of 1+x is 1/(1+x), but I'm lost. I'm not sure where to start nor what exactly I need to do.
You might want to start with the hint and find the McLaurin series for 1/(1+x).
Ok, I understand that I need to start with the maclaurin series, and I've done that, but I'm not sure what that shows me.
You might want to show us what you found for the MacLaurin series so we can make sure you are finding the correct thing. Then substitute N for x. What else? What does the nilpotency of N tell you about the infinite MacLaurin series?
ok well we know:
P(n) = 1 + x + ... + x^n
xP(n) = x + x^2 + ... + x^n + x^(n+1)
(x-1)P(n)=x^(n+1)-1
P(n) = x^(n+1)-1/(x-1) goes to -1/(x-1) = 1/(1-x) <== close to 1/(1+x)
if you use -x, P(n)= 1/(1+x)
because the MacLaurin series for 1/(1+x)
f(x) = f(0) + f'(0)x + f''(0)x^2 + ...
f(x) = 1 + x + x^2 + ...
The MacLaurin series for 1/(1-x)=1+x+x^2+x^3+x^4+..., yes. Doesn't that make the series for 1/(1+x)=1-x+x^2-x^3+x^4-...?? Taking x->-x, just as you said?
yes...
Let P(n) = 1-x+x^2-x^3+x^4-...+x^n
xP(n) = x-x^2+....-x^n+x^(n+1)
add them
(x+1)P(n)=1+x^(n+1)
therefore P(n)=1+x^(n+1)/(x+1) which goes to 1/(1+x)
angelz429 said:
yes...
add them
(x+1)P(n)=1+x^(n+1)
Ok, so what happens when x is the nilpotent matrix N??
angelz429 said:
so how does this show that I + N is invertible?
The inverse of I+N is 1/(I+N). Does the MacLaurin expansion converge??
