Solving ODE Problem: y'=(y^3)/2, y(0)=1
  • Thread starter wakko101
    Ode
7 replies · 2K views · last reply
wakko101
I'm having trouble finding the solution to the following ODE:
y'=(y^3)/2 with initial value y(0) = 1
I try to separate it but end up with
y^2=-1/x
which makes no sense, since you can't take the square root of a negative number.
Any help?
Cheers,
Lauren. =)
You *can* take the square root of a negative number, but the answer will be complex. Don't forget your constants of integration also, which should help you solve this problem.
Even worse 1/x is not defined at x=0. You are forgetting to put in an integration constant.
Good point with the constants. So...
1/(y^3) dy = 1/2 dx Integrate both sides
-1/(2y^2) = x/2 + c
y^2 = 1/(-x - 2c)
this solves the problem with it being undefined at 0, but at this point, I guess I need to add my complex number i?
y = i/(x+2c), which would make c=i/2 and so y = 2i/(2x + ci)...I think.
Is this right?
we haven't really used complex numbers so far in this particular course, which was why I was hesitant to use it in the answer.
Cheers,
L.
Nooo. Just put y=0 and x=1 and solve for C. Those are your initial conditions. I don't think you have to solve for y.
okay...so, then, plugging in my initial values at the Y^2 point, I get:
1^2=-1/(0+2c) ==> c=-1/2 ==> y^2=-1/(x-1) ==>
y^2 = 1/(1-x) ==> y = sqrt(1/(1-x))
Is that it?
Cheers,
L.
