Solving polynomial equations with fractional coefficients
  • Level: Undergrad
  • Thread starter ACLerok
    Polynomial
9 replies · 3K views · last reply
ACLerok
Hi, I was just reading up on some material for one of my exams and came across something. I realize this may seem like a trivial, obvious question but:
What is the easiest way to find the solutions of the polynomial (for example):
(x^2) - (1/6)x - 1/6 = 0
Other than guessing and testing for the correct values of x, what is the quickest and most efficient method of solving for x when the coefficients of each term is a fraction rather than a whole number? Thanks in advance.
well you just let your fraction, 1/6, equate to b, as the equation was a quadratic of the form [itex]ax^2 + bx + c = 0[/itex]. Then substitute your values for a, b and c into the quadratic formula, [tex]x=\frac {-b(+-)(b^2 - 4ac)^0.5}{2a}[/tex] If you mean in general, you it is quite hard to solve equations of degree 3 and 4 analytically, and after 5 it can only be approximated using methods such as Newtons Method.
Given the equation
[tex]x^2 + px + q = 0[/tex]
the solutions are:
[tex]x_{1} = - \frac{p}{2} - \sqrt{ \left( \frac{p}{2} \right)^2-q }[/tex]
and
[tex]x_{2} = - \frac{p}{2} + \sqrt{ \left( \frac{p}{2} \right)^2-q }[/tex]
So in your example:
p=-1/6 and q=-1/6
one more thing: if I am trying to find the solutions if the polynomial is of order 3, for example:
x^3 + 0.5x^2 - 0.25x - 0.125 = 0
Do I add 0.125 to both sides then factor an x or do must I do something else? Thanks
Wow what a long and involved process :cry:
There is no other process of finding them? oh well
Thanks
You can try to find (adjust) one solution ([tex]x=0.5[/tex]). After that you can divide [tex]x^3 + 0.5x^2 - 0.25x - 0.125[/tex] by [tex]x-0.5[/tex].
The result is [tex]x^2+x+0.25[/tex].
So [tex]x^3 + 0.5x^2 - 0.25x - 0.125=(x-0.5)(x^2+x+0.25)=0[/tex]
You already can solve it.
Thanks
Not all problems easily stated are easily solved.
Most happen to be insoluble, I'm afraid.
arildno
I don't think that ACLerock solve very difficult problems.
It is possible to apply more easy methods when solving home and exam tasks.
(for example the method from my post).
