Solving problems in function notation
  • Thread starter Thread starter Daringpear
    Function Notation
The discussion revolves around solving for g(3) using the function notation provided. Given that g(1) = 3 and the equation g(2x + 1) = 4g(x) + x + 1, participants explore how to derive g(3). By substituting x = 1 into the equation, they find that g(3) can be calculated as g(3) = 4g(1) + 2, leading to the solution g(3) = 14. The approach emphasizes understanding the transformations of the function and utilizing known values effectively. The final answer confirms that g(3) equals 14.
Daringpear
Given that:
g (1)=3
g (2x+1)=4g (x)+x+1
Find g (3)
The awnser is 14. (Taken out of a PSAT workbook)
I assume that g(2x+1) refers to a series of transformations (horizontal dilation, up 1) of g(x)
Once g(x) is found, g(3) can easily be solved. The problem is, that I have no idea how to find it.
The second equation tells you how to find g(2x + 1) if you already know g(x).
For which value of x do you already know g(x)?
Daringpear said:
Given that:
g (1)=3
g (2x+1)=4g (x)+x+1
Find g (3)
To me it appears you think a little bit too complicated.
Can you write ##3## as ##2x+1## and what does it tell you about ##x##?
Ah! Your suggestions make sense!
When substituting x for one,
g(2(1)+1)=4g(1)+1+1
g(3)=4(3)+2
g(3)=12+2
g(3)=14
  • · Replies 23 ·
26K
