Solving Quadratic Equation: 1{(1-x)^1/2+1} +1{(1+x)^1/2-1}=1/x
  • Thread starter Thread starter 1/2"
    Quadratic
The discussion revolves around solving a quadratic equation involving square roots, specifically the equation 1{(1-x)^1/2+1} +1{(1+x)^1/2-1}=1/x. Participants are exploring various methods to manipulate and simplify the equation.
  • Mixed
  • Some participants suggest rewriting the equation with proper parentheses for clarity. Others propose squaring both sides to eliminate square roots and simplify the expression. There are attempts to multiply terms by their conjugates to facilitate simplification. Additionally, questions arise regarding the validity of the original equation and the potential for real solutions based on the domain of x.
The discussion is ongoing, with various approaches being explored. Some participants have provided guidance on manipulating the equation, while others express uncertainty about the existence of solutions. There is no explicit consensus on the correct method or outcome at this stage.
Participants note the importance of considering the domain of x, particularly that values outside of -1 to 1 may lead to complex solutions. There is also mention of potential errors in the original problem setup, which could affect the solving process.
1/2"
1 {(1-x)^1/2+1} +1{(1+x)^1/2-1}=1/x
I can't got any clue how to solve it!
I tried to multiply the terms with the LCM of the denominator but bit doesn't help.
Please give me a clue!:frown:
Thank you.
Is this your equation? You really need to put parentheses around your exponents.
[tex]\sqrt{1 - x} + 1 + \sqrt{1 + x} - 1~=~1/x[/tex]
If the equation above is correct, try squaring both sides of the equation and simplifying. Then, you should be able to have nothing but square roots on the LHS. Then, square both sides again. This will allow you to get rid of the square roots. At this point, foil both sides. If you do it right, you will be left with a quartic expression that looks something like this: [tex]0=ax^{4}-bx^{2}+1[/tex]. Then, all you have to do is find the roots.
The equation should be
1 /{(1-x)^1/2+1} +1/{(1+x)^1/2-1}=1/x
I am very sorry for the mistake!
For starters, multiply each term on the left side by 1. For the first term, multiply by sqrt(1 - x) - 1 over itself. For the second term, multiply by sqrt(1 - x) + 1 over itself.
Next, multiply both sides by x, which will give you an equation with two radicals on one side and an integer on the other side. You should be able to solve the equation pretty quickly after that.
Pretty sure this is the eq:http://img32.imageshack.us/img32/8351/mathimage.gif
Tried solving and it has no solution.
I tried as well and couldn't find anything useful to simplify the expression.
Following Mark44's hints, I ended up with
[tex]\frac{x\left(1-x\right)^{1/2}+x}{2-x+2\left(1-x\right)^{1/2}}+\frac{x\left(1+x\right)^{1/2}-x}{2+x-2\left(1+x\right)^{1/2}}=1[/tex]
I looked at this relation graphically and found the solution (if we are only considering real numbers), but I can't figure out how to solve the equation from the point above.
To help me try an figure out if there could be a real solution, I took the equation above and replaced the 1 on the RHS with f(x). Then I asked for what value of x would f(x)=1. The important thing to realize is that if we are looking for a real solution -1≤x≤1 because of the opposing signs in the radicals. Any value of x outside of this domain will produce complex numbers, so they couldn't satisfy f(x)=1.
I'm curious to know what kind of class this problem is for. If it is a high school algebra or intro college algebra, perhaps the OP mistakenly wrote the wrong signs in the radicals. If the signs in the radicals are supposed to be the same, then the solution is +3/4 with the sign depending on the sign in the radical. Or maybe I just don't understand how to manipulate radicals well enough for this problem.
Any ideas Mark44?
[tex]\frac{1}{\sqrt{1 - x} + 1} + \frac{1}{\sqrt{1 + x} - 1}~=~\frac{1}{x}[/tex]
If you do exactly as I said in post 5, this equation becomes
[tex]\frac{-\sqrt{1 - x} + 1}{x} + \frac{\sqrt{1 + x} - 1}{x}~=~\frac{1}{x}[/tex]
Now multiply both sides by x. This won't cause us to lose a solution because the original equation isn't defined if x = 0.
[tex]\sqrt{1 + x} - \sqrt{1 - x}~=~1[/tex]
With equations involving radicals like these, it's a little quicker to move one of them to one side of the equation before squaring both sides.
[tex]\sqrt{1 + x}~=~\sqrt{1 - x} + 1[/tex]
Now square both sides, do some simplification, and square both sides once more.
I end up with x = +/-sqrt(3)/2
Ahhh. That's nice. I see where I went wrong. When I was multiplying each term on the LHS by 1, I didn't change the sign in front of the 1. In other words, I multiplied the first term by sqrt(1 - x) + 1 over itself and the second term by sqrt(1 + x) - 1 over itself. That is a nice tool. I am going to keep that in my pocket for later. Thanks for showing us that.
The basic idea here is a number times its conjugate being used to simplify an expression with a square root. (a + b)*(a - b) = a^2 - b^2. If a and b are square root expressions, this gets rid of them. Note that the same trick doesn't work for cube roots, but there is another one that might be helpful, namely (a + b)(a^2 - ab + b^2) = a^3 + b^3. Also, as appropriate, (a - b)(a^2 + ab + b^2) = a^3 - b^3.
  • · Replies 24 ·
