Solving Scalar Product Problem: Find Perpendicular Distance
1 reply · 5K views · last reply
pavadrin
Hey,
Today I was given a problem to solve in class and was told to complete it for homework. This problem is as follows:
The line y=mx + c has a gradient m and cuts the y-axis at (0,c). Thus we can write the parametric vector equation of the line as:
[tex]r = cj +\lambda (i + mj)[/tex]
Using this fact show that that the perpendicular distance from point [tex]A(x_1 , y_1)[/tex] to y = mx + c is:
[tex]\mid(\frac{mx_{1} - y_{1} + c}{\sqrt{m^2 + 1}})\mid[/tex]
If y = mx + c is instead written as ax + by + d = 0 show that the perpendicular distance of point [tex]A(x_1 , y_1)[/tex] to as ax + by + d = 0 is given by:
[tex]\mid(\frac{ax_{1} - by_{1} + d}{\sqrt{a^2 + b^2}})\mid[/tex]
This diagram which I drew to help me may help:
Coordinate diagram of a line y = mx + c through (0,c) on the y-axis, with a right-triangle run of 1 and rise m, a point P on the line, and a red perpendicular segment from P to point A labelled (x1,y1).
______________________​
I have tried solving this problem by using vectors:
Handwritten-style working in vector notation: OP as (0, c) plus lambda times (1, m); AP equals AO plus OP, giving (1 - x1, c + lambda m - y1) after substitution.
and I know that the dot product of [tex]( x_1 , y_1 )[/tex] and y = mx + c is equal to zero but from there onwards I am not sure on how to approach this problem. All help is appreciated,
thanks, Pavadrin
First, you need to find a vector perpendicular to the line y = mx + c. Call this vector u. Let v be the vector that points to A. Then for some n, nu + v = r. The magnitude of nu is the perpendicular distance from the point A to the line y = mx + c.
