Solving simultaneous equations in a Do-Loop with Mathematica 7
  • Context: Mathematica
  • Thread starter Thread starter kaizen.moto
    Mathematica
2 replies · 2K views
kaizen.moto
Hi all,
I got stucked with the problem with regard to Do-Loop and solving simultaneous equations together.
Please help me on this matter and the file is attached, Iam using Mathematica 7
Thanks
In Task 1 in (W1r)=(3m*n(Ar+Ar+1)...)) there is a missing ; and there are missing or extra {} or levels in your matrix equation that give errors. Once I try to guess what to do to fix those then it grinds away producing 37500 matrix equations and I assume it will finish in the future.
Task 2 is written in a very strange way but it does what you seem to request.
Task 3 is very difficult to understand. Substitute A0,A1,B0,B1 from Task 2 is clear. But substitute in what? In Task1? Sum W1r=0 what? In Task1?
To do substitutions in an expression usually you use
expression//.{A0-> -U10,A1-> -U11,B0-> -V10,B1-> -V11}
and that will replace all A0, A1,B0,B1 with your desired values in expression.
To Sum usually you use
Sum[W1r=0,{m,1,99,2},{n,1,99,2}]
if you have assigned the desired expression to W1r.
But it is not clear that I am answering what you have asked for or you have asked for what you need.
Perhaps the physics forums OtherSciences->Math&ScienceSoftware would be a better place to ask Mathematica syntax questions.
Perhaps you can see how to adapt this very simple example to your actual problem.
In[4]:= w=3m*n*a+8n^2*b;
rules=Solve[{a+u==0,b+v==0},{a,b}];
Sum[w//.rules,{m,1,5,2},{n,0,3,1}]
Out[6]= {-162 u-336 v}
