Solving simultaneous recurrences by diagonalising a matrix
33 replies · 6K views · last reply
ShaunDiel
Solve this simultaneous pair of recurrences using diagonalisation
Not sure what would be related equations to this.
Originally I had no idea how to do this, I set up the first matrix, like this.
Then, from there, I know that I have to let:
x_k= [[c_k][d_k]]. Then x_k = A^k x_0,so you want powers of A. If you find its eigenvectors, then A = P * [[lambda_1, 0 ] [ 0, lambda_2]] * P^-1, so A^k is P*[[lambda_1^k, 0 ] [ 0, lambda_2^k]]*P^-1.
I just don't understand the syntax in this and how to put it to paper
Please give me a push in the right direction, I've been stuck on this problem all day.
ShaunDiel said:
Anything ? :s
The problem said you should use diagonalization of your matrix. First find the eigenvalues and eigenvectors.
Is A the correct matrix to diagonalise though? I did it out right now and usually on test problems our prof makes everything work out fairly nicely but this worked out to be:
λ^2 - 13λ -5070
Divided by 143 in front
λ^2 - 13λ -5070
It does work out sort of nicely. That equation at least has integer roots. Not nasty radicals. If this is a test question, I probably would have tried to find something nicer though.
Oh damn, it factors too,
So I have my two Eigenvalues:
λ1= 78
λ2= -65
Should these be divided by 143? Or Can I leave that alone to solve for my eigenvectors?
λ1= 78
λ2= -65
Find the eigenvectors of the integer matrix first. Do you know what you are going to do with the eigenvalues and eigenvectors once you find them? It doesn't hurt to look ahead.
Dick said:
You can find the eigenvectors of the integer matrix first, then divide by 143 later. Do you know what you are going to do with the eigenvalues and eigenvectors once you find them? It doesn't hurt to look ahead.
Well, I'm solving for my Eigenvectors now, All 4 numbers in both matrices are multiples of 11, after that would I do the:
D= P^-1 A P ?
D= P^-1 A P ?
That was the point to the "looking ahead" idea. If your initial condition are an eigenvector, then you know what happens. If it a mix of the largest eigenvalue and the smaller eigenvalue then you should also know what will happen.
This is where I start to get lost,
I 'solved' for my eigenvectors by plugging in λ1 & λ2, Which resulted in 2, 2x2 matrices, simple row ops removed a row yielding :
1) 1/143 [1 3]
2) 1/143 [-4 1]
So [x,y] = (3,1)t & (1,-4)t
Now I'm lost :(
1) 1/143 [1 3]
2) 1/143 [-4 1]
Now I'm lost :(
Ok, so you've got the two eigenvectors. v1=(3,1) and v2=(1,-4) and they correspond to the eigenvalues λ1=78/143=6/11 and λ2=-65/143=-5/11. You initial state is (15,18). Can you express that as a linear combination of your eigenvectors? Now it should be easy to say what cn and dn are.
I have no idea how to do this at all, I've been watching youtube videos for the past hour trying to figure it out and there's nothing in my textbook regarding recurrences :confused:
EDIT: Does it have anything to do with the initial conditions being multiples of 3 of my eigenvalues or is that just a coincidence?
You just want to solve a1*(3,1)+a2*(1,-4)=(15,18) for a1 and a2. If you express it in components it's two equation in the two unknowns a1 and a2.
Ohh okay, so setting up the system of eq's:
3a1 + a2 = 15
a1 - 4a2 = 18
∴ a1 = 6
a2 = -3
3a1 + a2 = 15
a1 - 4a2 = 18
∴ a1 = 6
a2 = -3
Fine. So now you've expressed (c0,d0)=6*(3,1)-3*(1,-4). Since (3,1) and (1,-4) are eigenvectors of A, it should be easy to write down an expression for (cn,dn)=A^n(c0,d0).
I'm sorry, I feel like I'm useless at this..
Do I not have to do the D= P^-1 A P stuff?
A(3,1)=(6/11)*(3,1). A^2(3,1)=(6/11)^2*(3,1). Use that you have eigenvectors in the expression.
I just really don't understand what's going on.. I have
A[1,-4] = (-5/11)*[1 -4]
A[3 1] = (6/11) & [3 1]
But what am I trying to do? Get what in terms of what? :s Thanks for being so patient with me I feel like an idiot
Apply A again to both sides of those equations. Imagine what would happen if you applied A n times.
Like just multiply them?
So if I took A*[1 4] it would be [199/143 -172/143] ??
No, multiplying it out sort of misses the point. If A[1,-4]=(-5/11)[1,-4] then A(A[1,-4]))=(-5/11)*A[1,-4]=(-5/11)*(-5/11)*[1,-4]=(-5/11)^2[1,-4]. So A^2[1,-4]=(-5/11)^2*[1,-4]. What about A^3[1,-4]?
Dick said:
No, multiplying it out sort of misses the point. If A[1,-4]=(-5/11)[1,-4] then A(A[1,-4]))=(-5/11)*A[1,-4]=(-5/11)*(-5/11)*[1,-4]=(-5/11)^[1,-4]. So A^2[1,-4]=(-5/11)^2*[1,-4]. What about A^3[1,-4]?
Would it just be A^2(A[1,-4]))=(-5/11)*A^2[1,-4]
A^3[1 -4] = (-5/11)^3[1 -4]
∴A^n[1 -4] = (-5/11)^n[1 -4]
Sure, that's it. Powers of A applied to eigenvectors are easy to compute.
Sweet! So does that finish all the diagonalisation for part A?
I think so. You've found a basis of eigenvectors for A and you've expressed [c0,d0] in terms of them. Now you should be able to write down formulas for cn and dn.
Okay so I have both general forms for the eigenvectors, how would I write a formula for cn & dn from those though?
Try it! You found [c0,d0]=6*[3,1]-3*[1,-4]. You want to find A^n of that. You know how to find A^n of the eigenvectors, right?
Do I just do it the same way as before? Applying A to both sides?
So: A[c0,d0] = =6*A[3 1] -3 *A[1 -4]
Sure. But why not apply A^n to both sides? The left side becomes [cn,dn] doesn't it?
Oh damn, so it does.
So I'll have :
[cn dn] = 6*A^n[3 1] -3 *A^n[1 -4]
as the expression for cn & dn? or should they be seperate?
I'm guessing separate since it asks for a ratio in part b)
