Solving Sound Waves Problem: X vs Y
The discussion revolves around a problem involving sound waves X and Y, focusing on their wavelengths, amplitudes, and frequencies. Participants are tasked with determining the intensity relationship between the two waves and how much louder one is compared to the other in decibels.
  • Participants explore the relationship between intensity and amplitude, questioning the proportionality of intensity to the square of amplitude. There is discussion about the equations for intensity in terms of displacement and pressure waves. Some participants express confusion about the values provided for amplitudes and how they affect the calculations.
The discussion is active, with participants offering various equations and interpretations. Some guidance has been provided regarding the logarithmic relationship in decibels, and there is an ongoing effort to clarify the initial conditions of the problem. Multiple interpretations of the problem setup are being explored, particularly concerning the amplitudes of the sound waves.
There is some ambiguity regarding the amplitudes of the sound waves, as initial posts suggest different values. Participants are also questioning whether intensity varies with wavelength and frequency, which adds to the complexity of the discussion.
FlipStyle1308
I am clueless on how to approach the following problem, and was wondering if anyone would be able to help me. Thanks!
Sound waves X and Y have wavelengths of 1 m and 2 m, and amplitudes of 0.01 Pa, respectively. The frequency of X is 343 Hz, and the frequency of Y is 171.5 Hz. The intensity of Y is greater than that of X by ___ times. Soundwave Y is ___ dB louder than soundwave X.
For the 1st part of the question, it may be helpful to note that Intensity\propto (Amplitude)^2
Just to double check, does that symbol mean indirectly proportional?
No, it mean directly proportional to. If you wish to form an equality you must add in a constant I = kAmp^2
~H
So would this be the answer...
The intensity of Y is greater than that of X by 10,000 times. Soundwave Y is 100 dB louder than soundwave X. ?
I don't see how you got 10000.
sound waves are abit tricky because there are two ways to represent them: in terms of a *displacement wave* or in terms of a *pressure wave*.
If I recall correctly (don't take my word for it!), the formula are
I= {1 \over 2} \rho v \omega^2 s_{max}^2 in terms of the displacement amplitude or I = {1\over 2} {\Delta P_{max}^2 \over \rho v} ( I am quoting from memory, I don't have my books here so caveat emptor). You must have seen these equations?
So I am a bit confused. If the two waves have the same *pressure* amplitude, they would have the same intensity (after checking that they travel at the same speed and they do..as they must :smile: ).
If you were given the *displacement* amplitude to be the same, I could see how the different frequencies would influence the result.
So I am :rolleyes: confused.
I used the equation that Hootenanny gave and plugged in the amplitudes of 0.01Pa and 1 Pa, getting inertias of 0.0001 and 1, respectively. 1 is 10,000 times bigger than 0.0001, and that is how I got my answer.
Decibels is given in terms of logarithms,
I(dB) = 10\log \left( \frac{I}{I_0} \right)
and can be use to compare increases in intensity.
more information is given here; http://hyperphysics.phy-astr.gsu.edu/hbase/sound/db.html#c1
Apologies for the confusion, but my answer is post #4 was a direct answer to your question in #3.
~H
Okay, I am confused with all these equations. Are you guys able to provide me a step-by-step process for solving this equation?
I think there is some confusion among the posters because there may be something you left out in your first post. In it, you wrote "Sound waves X and Y have wavelengths of 1 m and 2 m, and amplitudes of 0.01 Pa, respectively". Does the value of 0.01 refer to X, Y, or both? If I am not mistaken, X has an amplitude of 0.01 Pa and Y's is 1 Pa, as you mentioned in one of your later posts that "I used the equation that Hootenanny gave and plugged in the amplitudes of 0.01Pa and 1 Pa".
Perhaps you would like to clarify?
Sound waves X and Y have wavelengths of 1 m and 2 m, and amplitudes of 0.01 Pa and 1 Pa, respectively. The frequency of X is 343 Hz, and the frequency of Y is 171.5 Hz. The intensity of Y is greater than that of X by ___ times. Soundwave Y is ___ dB louder than soundwave X.
Fixed. I didn't notice that! Sorry! Is my answer still correct?
Does intensity vary with wavelength and frequency? If no, then I think your answer of 10,000 for the 1st part of the question should be correct.
For the 2nd part, use the equation that Hootenanny gave in post 8 (note that the logarithm has base 10). You may not know the absolute values of the intensities, but this should not be a problem. Just let the intensity of X be a and the intensity of Y be 10,000a and you can go from there. Also, remember that I_{0} in the equation given is a constant.
So I solve for:
10log(10,000)? How do I plug these intensities in?
I don't really get what you mean by "plugging the intensities in". Perhaps you would like to show some working?
I got it correct, thanks for the help!
Good! But take note of the fact that I_{0} is a constant value (the threshold of hearing, if I understand it correctly). The log_{10}(I_{0}) term should cancel off when you are doing your working.
  • · Replies 19 ·
