Solving Switch Statement Problem with y as Integer
  • Thread starter Thread starter magma_saber
    Integer Switch
2 replies · 2K views
magma_saber
switch statements. y is an integer number. Use a switch statement to set B equal to one of the following values: true, false, or the vector [1 0 1]. If y is {1,2,3,5,7}, then set B to true. If y is {4, 6, 8, 10}, then set B to false. If y is neither, then set B to the vector [1 0 1]. You must use a switch statement to solve this problem and your answer should be stored in the variable named "B".
B='true'
switch B
case '{1,2,3,5,7}'
y=true
case '{4, 6, 8, 10}'
y=false
otherwise
y=[1 0 1]
end
i tried that and it said it was wrong. a file was provided that tells you if its wrong.
I believe you want your switch to be the criteria you are comparing, ie. y and your statement following the case to be B (the variable you are assigning a value to).
Switch y
case '{1,2,3,5,7}'
B = true
case '{4,6,8,10}'
B = false
etc
never mind i figured it out.
