Tetherball: find tension and angle when ball completes 2 circles per second
  • Thread starter Thread starter ybgl
5 replies · 4K views
ybgl
A .3 kg ball is attached to a string that is 50.0 cm in length, and completes 2 circles every second. Find the tension required to whirl the ball with the given constraints and also find the angle θ
2. The attempt at a solution
I only have that Ftcosθ = Mg and that mv^2/r = ftsinθ
I don't know where to go from there since all I have is the length and mass because to find the radius it is r=Lsinθ which I cannot find without θ...
Welcome to PF!
This is just an algebra problem now. You have done the physics!
2 equations. 2 unknowns. Solve. Hint: try dividing the two equations.
AM
I have tried, it gives me (g)(r)sinθ/cosθ=v^2 which is 3 unknowns since I don't know radius, velocity, or θ
You can work out r from L and θ. θ is the downward angle that the tether makes as measured from the horizontal, so r = Lcosθ. Just substitute into your equation.
v can be determined from the period and radius. Or you can just use mω2r for centripetal force.
AM
AM
And where do the solution go from here .Kind of stuck somewhere
Welcome to PF, @Lesleyanne :smile:
This thread is over 8 years old, so it's best if you start a new thread here in the Homework Help, Introductory Physics forum and show your work on your problem. That's the best way to get tutorial help with your schoolwork here. Thanks.
